Question about Hotpoint First Edition WMA22 Front Load Washer
Water pouring from soap draw
We think the machine may be blocked, so where would we look for the problem ? the water pours from the soap draw, even though whenw e put it on the rinse programme water still comes out of hose outlet but why is water coming out of the draw?
  • 2 more comments
  • George Gunn Nov 12, 2007
    I am Having the same problem, the machine is fine until it goes into a rinse cycle then the water pors out the drawer, I have cheked the pipes and there doesnt seem to be a blockage anywhere. any help would be apprecaited George
    Hi there i am having the same problem, the machine is fine until it goes on a rinse, then the water comes gushing out the drawer, doesnt seem to be a blockage in the pipes
  • sarah47 Apr 26, 2008
    Water pouring out of soap tray does not appear to be any foreign matter or a blockage in the outlet pipe
  • Anonymous Mar 19, 2014
    Water comes out of soap draw
    President:
  • 878 Answers
Angie, pull the drawer all the way out and see if you have a lid seal blocking the inlet tube. There should be a releasing tab in the back. Just take your finger and feel where the fill port is. I have found many bottle lid seals blocking this fill port. Catriver..post back.
Posted on Oct 01, 2006
April Air 560: water is pouring out of the unit casing, along the seam,not into the tube. Water pad is not even wet. I think the water flow is somehow missing the pad and collecting in the housing.
feel water pipe from soap dispenser could be blocked with soap it will feel solid clear with a length of wire carefully so as not to puncture hose flush with hot water to remove remaining soap
Dec 09, 2016 | Washing Machines
Water pouring out of the detergent drawer
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
Mar 19, 2014 | LG WM2101H Front Load Washer
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water is coimg out from the section were you put powder in
even the water pressure to the washing machine is too high, the machine is tilted forward or a blockage in the soap hose/ draw inner preventing water going down.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
WATER IS POURING OUT THE DISPENSER DRAW OF MY WF000G
Normally if you take the soap slide draw out,you will see a hole underneath where the slide draw was. It normally blocks up with undesolved soap. Clear the channel then retry.Or sometimes water pressure is to high and then tends to splash internally causing water to drip out. Also make sure the slide draw is cleaned properly..
Sep 21, 2009 | Washing Machines
Water is pouring out of where the soap dispenser is. Can anyone help?
its pouring out because the dispenser is getting clogged in somewhere and not letting the water to the drain pump so its pouring from the soap dispenser. Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly , open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Jul 09, 2009 | Kenmore 43142 Front Load Washer
When wash starts water pouring out drawer
take your soap draw out and seif it blocked sometimes the washing powder blocks the pipe to the drum you could also try and boil you kettle and poar in the soap draw
Jun 24, 2009 | Hotpoint Washing Machines
Leaking Washing Machine
no you should not need to spend any money on this . it sounds like the hose going from the back of the soap draw to the drum may be blocked just boil your kettle and pour it into the draw if this clears the blockage you wil see steam in the drum then put more hot water about another 2 kettles full down the draw and push the draw in and operate machine on the spin cycle. if the blockage is still there take off the lid you will see the hose from the back of the soap box and sqeeze it this should release the blockage
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Hotpoint Aquarius WF000 - water problems.
have u tryed to clean the fillter at the back of he machine
Jul 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint First Edition WMA22 Front Load Washer Logo
169 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
