My daughter hit our t.v screen on the right side and here is what we have now. The screen on right side looks like someone poured yellow dye down it. Everything is highlighted in blue (like 3 d). Tried all of the convergences. Red lines up good and green seems ok. Blue is way off on the right side and I can't move the crosses at all. There are only two crosses on the top left that line up ok and turn white. All of the other ones are way off. I am wondering if it can be fixed by a repairman. I hate to spend too much money for an in home repair if its going to cost a lot. I would rather put the money towards a flat screen. I know this is not something I can fix myself but I have no idea what repairs to this extent would run. Thanks, Monique
If the CRT Projection television has several colors or one that arent lining up, if due to an impact - you may have a broken mirror, if just happened all by itsself it may be a convergence issue, either issue is repairable, probably for around $400-$500. I dont recommend taking a set like that into the shop as sometimes transport can break/crack a mirror or throw convergence off.
my crt picture is double up. I turned it off then back on a half hour later and then the picture was doulbed the colors are out of line on top of each other.
I am unable to remove the thinner red wire that is connected to tall tower to the far right of the...
(More)
I am unable to remove the thinner red wire that is connected to tall tower to the far right of the circuit board. It is a Panasonic PT-47WX42F RPTV. I am replacing the STK392-110 chips because the blue convergence is off and cannot be adjusted by remote. I am just wondering if there is a trick to getting this wire out. There is a thicker red wire connected to the same area. That one came out easily by pushing it in and twisting and pulling it out. They appear to be the same type of wire, but the push and twist method is not working with this wire. Is there a different technique to get it out?
when you watch a scroll going across the bottom it starts out fine but as it travels across the...
(More)
when you watch a scroll going across the bottom it starts out fine but as it travels across the screen it seems to be going downhill
I replaced the lamp assembly and the machine still states that it need a replacement lamp and now it...
(More)
I replaced the lamp assembly and the machine still states that it need a replacement lamp and now it will turn off at the drop of a hat. What the heck is up with this machine.
