Question about Kenmore Dryers
No heat have a Kenmore 80 series Mod. 110.64832400 everything works except the heat cycle - - - does that mean the element needs changed and if so can i do
  • cgoeke Jan 06, 2009
    I have the same problem now and it also happened last year.  I can't remember how I fixed it, but the problem was not the heating element.  I have checked my house fuses and all are fine.  Is there an internal fuse or breaker in this model?  Any help is greatly appreciated.
    Genius:
  • 1,122 Answers
If you have a meter you can check the element and fuse on the heater box,is your lint filter on top?if so you need to remove the back panel to get to them,make sure you unplug first,if you don't have a meter you can remove the heat element and look at it to see if any of the wires have broke,let me know how you do-mike
Posted on Nov 04, 2008
Kenmore dryer 70 series 66722690-everything works except does not heat
It is probably either the thermostat (sensing too hot a temp) or the heating element. Either is not that difficult to change.
A word to the wise: When I replace one I like to replace both. One of the first times I replaced an element, within a month I had to open it back up and replace the thermostat. And it has happened more than once, so now I replace both.
May 15, 2012 | Kenmore Dryers
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Feb 12, 2009 | Kenmore Dryers
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Dryers Logo
111 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
