Question about Whirlpool RBS305PD Electric Single Oven
Whilpool Double Electric Oven has NO POWER
My wife went to use the self cleaning option, and after some time had passed she noticed there was no power at all. I went to the look at the fuse box for the house and the circuit wasn't tripped but I reset anyway just in case. Still nothing. I can't open the door at all to the top as it auto locked. I read about replacing a fuse on the oven, where do I get direction on how to do this as I called up Whirlpool and they connected me to a local servicing company that wants to charge me $75 just to come out to look at the issue.
I had the same problem the first time I used the cleaning cycle. The oven was under warranty when it occurred so I watched the repairman when he fixed it. He not only installed a larger fan, but he had to replace a thermocouple that is on the back of the oven, part number 4450934. The oven seems to die (lose power) after every cleaning cycle. I'm now ordering my third thermocouple. To replace the part, you have to pull the oven out from the wall to access the back. To do that, open the oven door. (If your door is locked because of the cleaning cycle, you may have to take a hacksaw blade to slip it in to see if you can trip the latch. The repair man was lucky when he did mine as the door clicked open when he was just messing with it so I don't know any trick to get it unlocked. He said that because the thermocouple died, it didn't provide the signal to unlatch the door, so the oven thinks it's still at 500 degrees and keeps the door locked which is part of the safety process). If you do get the door open, on the sides of the oven itself, at the bottom inside hinge of the door, you will see a screw holding the molding (frames the side of the opening of the stove). Remove each screw (left side and right side at the bottom) and pull the molding off. You now have access to the screws that hold the oven to the cabinet that it is sitting in. Remove those screws (mine has one on each side) and you can then slide the oven out. It's heavy so you will need help or have some thing you can slide it on to. It needs to come out far enough so you can access the back. You will see the thermocouple on the back, held on with two screws. Remove the wires and take the part off and throw it away (or keep it so you know what to order again next time as you will be replacing it again after you do another cleaning cycle) GREAT WHIRLPOOL PRODUCT. Reverse the process and you will be baking in no time.
I
Posted on Nov 24, 2008
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Clean mode electric current went off was off 10mentis when it came back on oven didnt
I have a whirlpool double oven too and replaced the control board last year the problem started with a F06 code and would reset when I power cycled for a while until it completely quit. Changing the control board fixed that problem. I just used my self cleaning cycle recently and the oven went completely blank on the control panel. Power cycle didn't do any thing. I checked 2 of the thermal cutoff fuses that are shown on most of the parts listing but the problem was with one that is not shown. The link below will get you to the part I replaced it's the power feed to the control board. Turns out that the worst thing you can do to your oven is use the self clean feature. Oven Thermal Fuse
May 29, 2014 | Whirlpool GBD307PDS Electric Double Oven
Why when i used the self cleaning option on my upper oven will it not heat anymore?
Good Morning James,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
I cleaned my double oven and everything went blank, and I can't open the oven. I own clean the top oven. now the whole thing doesn't work.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 21, 2010 | Whirlpool RBD305PDS Electric Double Oven
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
heatman101
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Self cleaning won't shut off
that is because it needs to cool down before the oven will unlock.There should be a timer running and when it gets to "zero" it should unlock.
Jul 08, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Whirlpool RBS305PD Electric Single Oven Logo
158 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
