Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
Data recovery from External HD
Hi George,
I read your solution for a problem with an external hd that didn't work. Maybe you can give me some advice. My 500G Fantom does not turn on. The warranty does not cover data recovery. Should I attempt to recover the data myself? I saw you mention that a hard drive case can cost 7-25 bucks, is this something I can do myself? Please advise, I really appreciate it! Matthew
  • 95 Answers
Matthew,
First thing you should do is remove the drive from enclosure and connect it direcly to the PC or via another USB enclosure.
If it still doesn't power up then most likely the PCB is dead. You can try to find another drive of the same model and swap the PCBs. But as far as I know often this doesn't work.
Here's some info about burnt PCB (in the beginning): http://datacent.com/datarecovery/hdd/western_digital/
Take care.
Posted on Nov 05, 2008
External hard drive data recovery
data recovery services are the best possible option for you to recover all the data.
check http://bit.ly/1ve3b8v
Apr 18, 2015 | Hard Computers & Internet
My Buffalo hard drive was working fine but my computer had virus. I removed the virus and then copied a few files to the external hard drive. Later I realize that the virus wasn't completely remov
Consider a low cost data recovery service such as http://FreeDataRecovery.us
They do remote access data recovery over the internet and also offer do-it-yourself data recovery advice.
Oct 18, 2012 | Buffalo Technology HD-PX500U2/RD 500 GB...
Folder structure showing 0 files on external HD -after powersurge
You may use data recovery software to see if you can rescue the files on your external HD.
It may unable to recover all the files, but at least most of them.
Sep 27, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Could not recognize and no spin
I hate to be the bearer of bad news but from the sound of it you can't. At least not cheaply. The drive must be rebuilt to save the data. Your only option is to bring the drive to a HDD Recovery service for a Clean Lab Recovery. Expect to spend 600-1000.
Sorry Again :-(
Apr 28, 2009 | Computers & Internet
Maxtor 3200 external hd not working
I would attempt to connect the drive after the system has booted up. If the external drive is found and accessible copy the data to another drive. If the external refuses to be recognized, allow the drive to cool completely 2-3 hrs, place the unit in a freezer for 2-3 hrs and then try the procedure again. Often times when the drive units or platters within the HD begin to fail you get symptoms as you have described. Super cooling the drive sometimes allows you to remove the data. If not and the data contained within the drive is valuable to you there are software solutions as well as companies that specialize in the data recovery field.
Apr 25, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Cant See Data On WD External (500GB)
dear,dont take tention,if data is deleted accidently i can recover total data your using some software.
so first you try
1-remove some data from Hard disk
2-may be virus occured or attach with files.
yes you can easily recover the delete files.
Apr 12, 2009 | Western Digital 500GB My Book Pro-External...
Mybook essential edition
Hi, As I have responded to a similar post, this is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the WD500GB itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Western Digital 500GB My Book World...
Maxtor External 500 GB Hard Drive
Hi, 1. "Is the data recoverable?" Yes but the manner by which it can be recovered can be either very expensive (their are firms whose specialty id data recovery) or none at all if you do DIY (do it yourself) or worst case not economical reasonable but recovery possible. I would assume that your would want to try DIY. 1.1 Run diagnostic on the external drive using scandisk, Norton Disk Doctor, Partition Magic's ChkDsk and/or Check Errors. Recovery can be done using a recovery software such as GetDataBack; or 1.2 You need an external desktop PC, a working knowledge of computer hardware. You have to disassemble the external HD and remove the actual HD. Physicall connect it to the 2nd PC (desktop) as a seconday Master either by IDE or SATA as applicable. If detected by the desktop PC in the bios, you should be able to work on it even if with errors; 1.3 If mechanical problem or otherwise, you may want to check out this posting > http://www.fixya.com/support/t162904-seagate_barracuda_7200_7_st380011a Hope this works out for you and/or give you some ideas. Pls post again how things turn up. Good luck and kind regards.
Aug 05, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
157 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
