Question about Jenn-Air JMV8208AAS Microwave Oven
Venting I have the model JMV8208AAS for the past 2-years, it has a 5- speed venting, every time I put it on, the air is exhusting off the top above the door into the house, even though the venting is hooked up. it's not exhusting outside the house. What could be the problem ? there is no blockage. Please help Fazal.
  • 59 Answers
If this microwave has vented outside in the past then most likely a bird or something has built i nest in or on the vent blocking airflow. If its always been this way then in order for this model to vent though an exterior duct the blower motor has to be flipped so that it blows upwards and a vent connector needs to be installed. This is a fairly easy process once the microwave has been taken down but can be dangerous because there is a capacitor that holds 4000 volts that can discharge though the cabinet if you're not careful.
Posted on Nov 04, 2008
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
I've purchased the Whirlpool Model #: WMH73L20AS microwave and the venting fan not working (well). The intake under the microwave into the filter can be barely felt, but on the top part of the microwave...
I just returned mine.... I had 7 (SEVEN) service calls coming out for it.. and they tried everything to stop it from overheating...and shutting off... and finally after 4wks we called it quitts. its a venting design problem... inside the unit...
Aug 17, 2013 | Whirlpool Microwave Ovens
Jenn air microwave model jmv820aas shut down completely, what do i do?
I'm guessing you might mean JMV8208AAS?
If so, then the service manual is at our site here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Jenn Air parts here.
Your problem will be either the line fuse, or one of the thermal cutouts / TCOs in the unit.
In case it needs circuit board repair, see this link.
Nov 27, 2012 | Jenn-Air JMV8208AAS Microwave Oven
For the Jenn-Air Model JMV8208AA The microwave was dealer installed and is room vented. The vent does not pull vapors from the cook top of the oven. Regardless of the venting level used, the pull...
Sorry to read about your problem, I hope this helps you out.
Well first of all I would take a piece of paper or newspaper, and put it up by the vents, the paper should be sucked on by the vent.. If it does that you have suction. if it does not hold the paper, you should get a warranty repair, i am assuming this new.
If the unit is install to far above the stove you may have a issue.
But long story short, the room vented units, do not really pull much smoke, they pull better on outside venting. you are just putting smoke/steam back into the room, just a little cleaner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Jenn-Air JMV8208AAS Microwave Oven
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
I need to change the venting from back of the microwave to the top? Also, I have misplaced the manual for it if there is one on-line as well. Thanks Kirk
There should be although you most likely will have to pay for it. Most models only require that you take the cover off the top and put it on the back. There will be a plate on the top covering the vent hole, just take it off and place it over the vent hole on the back.
Please rate
Sep 05, 2009 | Jenn-Air JMV8208A Microwave Oven
Whirlpool microwave oven mh7155xmb0 not venting
Possibly a bird built a nest (swallows) in or on the roof vent. Make sure the fan turns freely when off. Check the vent tube that goes up to the roof--if flex-tubing, it may have collapsed and pinched off the air flow (it may be too long). Make sure that a one-way valve which should be near the exit of the hood is free to move when air flow pushes on it. This valve is supposed to prevent back-flow of air into the house. Hope this helps!
Mar 09, 2009 | Whirlpool MH7155XM Microwave Oven
How does the vent work?
Under cabinet microwaves generally have two configurations for venting.
1) There is a vent cover plate on the top or rear (sometimes both) of the unit that can be removed and connected to a duct that vents up to the roof. If you do not have such a duct installed then that cover plate should be left on the unit so that it vents in configuration 2.
2) With the external venting ports sealed with the cover plate(s) the microwave simple draws air from the bottom (usually through 1 or 2 grease capture screens) and vents it out thought the front/top of the unit. This configuration isn't very useful as it just blows the air back into the kitchen. Many people don't both using the microwaves blower in this configuration.
Feb 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air JMV8000BAW
I always recommend that folks use the vent / hood fan anytime they're cooking with the stove.
Was it on at the time?
If not, moisture can certainly get into the works and cause problems or damage. If it dries out, it's fine but if not, it could cause damage.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 15, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Jenn-Air JMV8208AAS Microwave Oven Logo
167 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
