Question about Audiovox Jensen NVX-3000PC 7 Windows XP Personal Computer with Navigation PC Desktop
Bootup my jensen mobile table wont boot up
  • ed33058 Nov 04, 2008
    it only boots up at a certin point then it stops.when you see the line bar
  • Abramm Kalladorne
    Abramm Kalladorne May 11, 2010
    need more information. What does it do when you press the power button? Does the back light come on at all? How far does the boot process get? Does the computer only stay on for a few seconds and then turn off, or does it stay on and just not boot?
    Scholar:
  • 56 Answers
Ed,
Are you referring to the white underscore in the upper left corner of the monitor on bootup? It is very likely that a device driver is hanging on boot up.
To find out which one:
1. Upon restart, press F8 (several times) to force the Windows startup menu to load.
2. When the menu loads, select the option that allows you to manually confirm or deny the loading of each device driver.
3. When you have discovered which driver is not loading, perform another reboot, and do the step by step confirmation again, and say NO to that driver.
4. Finish loading windows, and correct the issue with the offending driver.
5. Reboot yet again, and allow windows to load normally.
Posted on Mar 06, 2009
Intel pentium - booting up ok, but nothing shows on screen. Pressed F12 came up with error message error setting up the MD3 over power button. Also, unable to locate media direct BIOS table.
If your computer is showing nothing on screen it is not booting up OK. Are there any beep codes being given during bootup? One single beep at the end of the POST sequence is OK, anything more means some kind of hardware error found during bootup. Media Direct 3 is a Dell product that has caused a number of problems on its computers. See Dell MediaDirect . Your option may be limited to contacting Dell support.
Jan 29, 2017 | Intel Computers & Internet
I deleted everything it wont bootup
Well if you deleted everything then of course it won't bootup.
Apr 12, 2014 | Dell Computers & Internet
Dell e5420 wont start up at all
Make sure no accessories are plugged into your laptop. First remove the battery and try a bootup. If does not bootup, remove the hard drive if you can and try again. If still no full boot, you can try the DVD drive and then the memory. Replace what you have found to be the problem. If none solves the bootup problem, it is either the power supply itself or a mainboard problem, which would required service from an authorized service center from Dell. Verify the center with Dell. The parts I have indicated to try are normally easily removed from the bottom of the laptop, by removing a few small screws.
Mar 15, 2013 | Dell Latitude E5420 Laptop Computer
Wont boot up,black screen.message on screen says,invalid partitio
When you power up your computer, the system examines the master partition table to determine what volume to use to boot up the operating system, and detected invalid information within it. This is caused by an incorrect or missing active partition.
To resolve this issue, consider the following steps:
  • Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  • At the DOS command prompt, type in: fdisk
  • Question - Do you wish to enlarge large disk support (Y/N) ?
  • Enter: Y
  • Now to check for active partition, enter: 2
  • Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  • If there's no active partition set, enter the number of the partition to make active
This must solve your problem.
Apr 15, 2010 | HP Compaq Presario 2200 Notebook
My laptop wont bootup display is "Operating System not found
If you have 2 RAM sticks, try removing one at a time and booting, if you have only one, then make sure it;s seated properly! also make sure everything else is seated properly, ie/ VGA card, NIC, Sound card etc...
Also before you reboot, reset ALL your Bios settings back to default, but your bootup option should be hard drive first boot. Hope this helps let us know the outcome please
Aug 06, 2009 | Samsung Q45 Notebook
My dell laptop wont do disk check and wont continue on windows what will i do to fix it
You should try to boot it into safe mode and then run a virus scanner you should also be able to run disk check in safe mode. Usually pressing the F12 key during bootup will bring you to the boot menu. You have to watch carefully because the option appears really fast at the beginning of bootup.
Mar 27, 2009 | Dell Latitude C600 Pentium III 750MHz,...
Hp nc6000 wont bootup
hi thanks for using fixya!
On this kind of error, the only option you could do is to format your system, but if you are not so familiar in formatting your laptop, I suggest that you bring laptop to service tech, to easily perform error checking and reformatting. This error might be virus or software problems.
Thanks! hope this will enlighten you. please rate me! good luck!
Mar 18, 2009 | HP Compaq nc6000 Notebook
Vpr matrix 1.8 mhz will not boot
press only the delete key restart hold the delete key
Mar 14, 2009 | Matrix 226R (VPR226R) PC Desktop
I cant uninstall spy doctor 5.5
Boot into Safe Mode... Do this by repeatedly pressing the F8 key upon bootup... you will come to a screen with bootup choices... choose boot to safe mode (the first choice)
then go to your Ad/Remove Programs from the control panel.. and proceed to uninstall... then reboot Normally..
Jun 04, 2008 | Toshiba Satellite P205-S6287 Notebook PC
New unit wont power on
Here is the manual:
http://mobile.jensen.com/jensen/docs/man/NVX200_DOC_OM.PDF
If that does not work send it in for warranty repair. Click the following link to setup the repair:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/ask.php
Hope this helps!
Thanks
Mar 24, 2008 | GPS
Audiovox Jensen NVX-3000PC 7 Windows XP Personal Computer with Navigation PC Desktop Logo
89 people viewed this question
Top Audiovox Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Greg Cann
Greg Cann
Martin Murray
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
