Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
How to replace small metal circular buttun cover (menu button)
Button cover come off (lost)
How to replace it please
  • jimlittle527 Nov 03, 2008
    central round menu button
  • dingling456 Nov 05, 2008
    yup da metal button is ttly out... & cant find it any where.. plzzzzz help
Pls tell the solution
Posted on Nov 17, 2008
Just call t-mobile and tell them the problem. If u still have a warenty they should send u another one. I had the same problem a few months ago.
Posted on Nov 06, 2008
I turn the blender on and a blue light turns on, blender isnt functioning, is it burnt out, is there a reset button besides unpluging it for a few minutes?
Unplug the blender. Use a baking soda and vinegar solution to clean the metal contacts on the bottom of the metal blender blade. (You will see a small circular inverted washer looking thing). Use the solution on the main blender unit also. (You will see a small circular metal piece in the center) Scrub them both with the solution and wipe. These seem to be some type of sensors. I then replugged the blender back in and it worked for me!! Good luck!
Aug 08, 2012 | Black & Decker BL1900 5-Speed Blender
My sync button crapped out so if anyone has this problem if you open the controller removing only the front cover and hold the sync button then make contact with the first and third contacts to each other...
Thanks for sharing this. All the buttons have a metal disc under the rubber sheath. So if you make contact with a metal circular button to the board it also works.
Feb 22, 2011 | Microsoft Xbox 360 Controller
I have a w1907 HP monitor. It keeps displaying a small box in the middle of the screen that says osd lockout. I am still able to get online and use my computer normally except for this box in the middle of...
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work. To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Jan 03, 2011 | HP w1907 LCD Monitor
Black & Decker BLC12600B 650W Cyclone 12-Speed, the on button blinks and the blender is not working. I have put into different sockets, it just doesn't work.
Sep 13, 2010 | Black & Decker BL14500 Crush Master Work...
How do you replace the battery in a ironman triathlon sleek digital watch
Thank you for contacting FIxYa.
Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • Remove the back case cover by gently prying it up with your screwdriver. Be careful to avoid disrupting any electrical contacts with the tip of your screwdriver.
  • Remove the interior sticker that covers the battery by lifting it up with the tip of your screwdriver. It should come off relatively easily. At this point the small circular battery should be visible in the compartment.
  • Lift up the small metal clip (battery strap) that covers the battery using the tip of your screwdriver.
  • Remove the battery from its housing and replace it with your new battery (available at any electronics store or online). Reassemble the watch in the same way you to took it apart.
  • Sep 01, 2010 | Timex Ironman Triathlon 50 Lap Digital...
  • Turn your Timex Ironman face down and remove the four screws holding the back cover in place.
  • OR take to a professional jewelry store/watchmaker.
    Good luck.
    Aug 21, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    Indiglo backlight works, but beep/chimes doesn't
    There should be a RESET switch right beside the battery slot. It is usually either the 2 pins that allow the battery cover to hinge up or down, or a metallic strip right beside the hinge. You will see the word RESET underneath the metal strip with a small round metal piece right below it. You need to take a small jewelers screwdriver and push the metal strip down to make contact with the small round metal piece. This will reset everything back to working order. You can then go ahead and set the time, date, etc. Sometimes it is necessary to reseat the battery and do the RESET one or two extra times but it should reset. If after all these steps you still can't get your chimes to work you may have to get your watch looked at.
    Jul 30, 2009 | Timex Expedition 40141 Wristwatch
    How do I replace the battery and where is it located?
    Procedure:
    Remove battery cover located under the hood on the passenger side in the back. Simply pry the plastic catch in the front, open it like a lid and jiggle it loose and set it aside.
    Use the small flat screwdriver to pop up the center peg in the five peripheral fasteners holding down the plastic compartment cover that you just removed the battery cover from. Each of these has a small black plastic circular flat topped center peg inside a larger plastic circular disk which has 4 slots under which you can slide the screwdriver to pop up the center peg. When the peg pops up simply slide the screwdriver under the larger disk to remove the assembly and loosen that site of fixation. When all five fasteners are out you can remove the entire compartment cover.
    The battery terminals are removed with the 10mm wrench
    The black box in front of the battery can be lifted out of the way by pressing on the plastic catch in the front of the box to loosen it from the metal flange that it is attached to.
    The metal battery holder is removed with the 10 mm wrench. The nut is removed and the long bolt is slid out of the holder and then unhooked from it's bottom anchor. Jiggle the metal bar over the top of the battery to unhook the back hook from its bottom anchor. It may be necessary to lift the plastic over the back of the battery gently and lift out the soft clear plastic washer fluid tube from its guides to get at the back hook.
    Gently lift the battery out while holding the cables out of the way.
    Tools required:
    10mm wrench, small flat screwdriver
    Procedure:
    Tools required:
    Procedure:
    Tools required:
    Procedure:
    Apr 17, 2009 | 2004 Nissan 350Z
    Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
    48 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    Rami Obeid
    Level 1 Expert
    D. E. Hev
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
