Question about Symphonic SL2960 VCR
No power Can't get any power to my vcr.It won't come on.Unplugged it a few times, plugged it back in.Anything I can check inside with a multi meter? Would like to try and fix it myself. LOL. Any suggestions? Thanks
  • Stephanie Davis Sep 30, 2006
    I found a blown fuse inside. I am going to replace it and see if it blows again.If so, then there is another problem.
    President:
  • 3,130 Answers
I you know how to use a multimeter then you can check to make sure the power supply is good by measuring the DC voltages on the regulator IC's and pluges. you will most likly need a service manual for this and it may not even be worth getting a manual as a good new VCR these days is only about 35 bucks and a manual could cost as high as 25 to 30 in most places.
Posted on Sep 30, 2006
  • Larry  Dillon
    Larry Dillon Oct 01, 2006
    Im sure there is another problem as fuses do not blow for no reason.
Dryer stopped working. Not spinning or anything
You will be needing someone with an electric meter, (an ohm meter or a multi-meter) to begin testing to find out if it is the dryer or the power source.
The one thing you could do is check the fuse panel or the circuit breaker box to see if a circuit breaker popped or a fuse blew.
The circuit breaker can be reset by flipping the handle a few times, a fuse would need replacement.
Other than that, an electric meter will tell if the plug socket is live or dead, and then the machine needs be taken apart to see which part has failed. Usually a fuse or a thermo-switch has popped inside the machine.
God bless your efforts.
Sep 08, 2015 | Avanti D110 Electric Portable Dryer
Why wont my eeepc charge ???
There could be three very good reasons I can think of immediately.
1) Check your power adapter to be sure it is working properly. You may want to find someone with a voltage meter to do this.
2) Check the power adapter plug on the laptop. These plugs are bad about becoming loose over time. When we use our laptops we tend to move them around especially if we are holding them in our laps. This causes the adapter plug to be pulled back and forth which can actually break it from the motherboard inside the laptop. No connection...no charge.
3) Be sure your battery is still good. Batteries can go bad like anything else and many times are the reason the PC won't charge.
Aug 26, 2011 | ASUS Eee 4G Notebook
I unplugged my dvd recorder. When I plugged it back in it won't power on.
Hello
Just look at the power chord, whether it has been pluged into the slot well. Check the wall power socket also for presence of power. Replug it to an other power plug point. Till the problem perists, surely there must be some fault with its power regulator board inside. Normally, if power regulator board gets power, the power indicator must light up. If not power regulator board [SMPS] board is faulty, and should be replaced with same type and number. OK.
Jun 27, 2011 | Philips Magnavox DVD/VCR Dual Player
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
Microwave made a click noise and stop working, no power at all!
Fist if it's plugged into a GFI socket,reset it by pressing the red button in the center back in & try it again. If that trips again,replace the microwave.If you dare, be carefull & unplug it, take the cover off. Should be held on by a few screws, & check the fuse inside. If it's solid white, then you need to remove it & check it for continuity with a multi-meter(ohm meter will do). If it's the clear kind, just look for the filiment to be burnt,like a light bulb. You can replace either kind with a standard glass fuse of the same amp rating. Whatever you do DON'T touch any of the circuits with bare hands! There's a transformer that holds enough juice in it to fry 5 people for months,even unplugged. If this scares you, it should. If you are uncertain about trying this,trow it out & buy a new one. Don't get hurt.
May 04, 2010 | Daewoo KOR-1B4H Microwave Oven
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Aug 24, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
VCR says safe
Hello. Have you tried unplugging the power from the VCR for more than 24hrs? This may resolve the "safe-mode" feature going back to "default" and permit regular use after this amount of time elapses. That is kind of unusual for the stepping upon the remote to cause this?
Jan 22, 2008 | RCA VR637HF VHS VCR
My DV-T5DN won't turn on...
your vcr timing is out or mode switch isfaulty.disconect vcr from plug for 20 sec plug back the tape mechanism should reset
Dec 23, 2006 | Daewoo DV-T8DN VHS VCR
Symphonic SL2960 VCR Logo
64 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
