Question about Memorex MVD2042 DVD Player
WILL NOT PLAY
MY DVD PLAYER WILL NOT PLAY DO I NEED IT ON A CHANNEL ? IT PLAYED BEFORE AND THE CABLE PEOPLE CAME AND HOOKED UP AND CABLE BOX AND NOW IT WILL NOT PLAY THE POWER COMES ON
    Scholar:
  • 124 Answers
Hi There, It sounds like the cable people change the connection. For me to help you, I will need a detailed description of every connection, from where it is connected to the other end of the connect along with the name of the connection. Thanks, Mike
Posted on Nov 03, 2008
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Cable box-dvd/vcr- tv hookup problems
    buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
    May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
    Magnavox DV220mw9 won't record from Tv, hard to connect
    check out this diagram, paying close attention to the audio video cable hookups.
    assume the cable tv box represents the converter box
    you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
    Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
    If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
    You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
    So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
    the tv will have to be set on the line input to view the signal from the dvd vcr combo.
    That is as easy as I can put it. Study the diagram closely. You will see what I mean.
    Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
    Problem hooking up DVD player to TV thru my cable box
    Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
    The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
    The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
    One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
    If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
    Feb 01, 2009 | RCA DRC277 DVD Player
    Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
    Hi and welcome to FixYa,
    Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
    • Charter Digital Cable > DVD/VCR > TV
    If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
    Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
    Pls post back results. Good luck and thank you for using FixYa.
    Jan 26, 2009 | Televison & Video
    Can't find dvd channel on my tv...
    hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
    shaun
    Mar 06, 2017 | Zenith SY2569X TV
    Trying to hookup and play standard DVD player
    Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
    Dec 12, 2008 | RCA F25441 25" TV
    Tv/digital converter box & vcr-dvd hook-up
    I have a vhs and dvd player all in one
    I have a converter box hooked up to my tv and vcr , dvd player combined
    I can play my movies on the tv. ok.
    you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
    Mine plays ok. My settings are for channel 3
    My suggestion would be to check your hook ups. maybe they are not hooked up correctly
    I had to go to www.google.com and did searches to help with hook up.
    I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
    I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
    Dec 04, 2008 | Televison & Video
    Dvd/vcr player is hooked up but not playing...
    Yes. You definitely need to set your TV on a specific channel - GAME, in your case. Check your TV manual how to get to that GAME channel.
    Jan 12, 2008 | Philips DVP3340V
    Memorex MVD2042 DVD Player Logo
    57 people viewed this question
    Top Memorex Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
