Question about Achiever CCS5000 Shredder
Squealing Shredder We have an Achiever CCS5000 Shredder that squeals when running. We don't have a manual. Could you please tell us how to obtain a manual or how/where/and what to oil the machine with? Thanks
    Scholar:
  • 75 Answers
You need to spray lubricant down the paper shout. the cutter wheels are dry. They make a shredder oil but you don't need that just a light what oil. wd40 is to heave. If the noise is still there then it is in the gear train and will need to br serviced.
but to much oil will make a build up of dust also it's a catchy 22
Posted on Jan 23, 2009
I have an Achiever CCS5000 shredder. On the base that holds the shedder part the safety post that must be up to run is broken. I need the part to fix. Where can I buy this part?
I also have one that i use off of the base. You can take the top off, 6 screws, make sure it is unplugged and locate the safety switch, cut the 2 wires & twist them together then use electrical tape to secure & insulate them. that will take care of the problem.
Feb 07, 2011 | Achiever CCS5000 Shredder
Our Achiever CCS5000 worked well until it was
Hi Alan,'
it is not available, you could find the interlock switch and jump them...cut wires off of switch and twist together, then use electrical tape.
Mar 03, 2010 | Achiever CCS5000 Shredder
I need a fuse for my ccs5000 achiever shredder. Do you know where one can be purchased?
Radio shack has a good selection. Make sure you match it exactly. Do not put a larger capacity fuse in there. It can burn the circuit board.
Jun 18, 2009 | Achiever CCS5000 Shredder
Acheiver CCS5000 screaching noise
A piece of metal or coin might have gone into the shredder.
Apr 22, 2009 | Achiever CCS5000 Shredder
I have a ccs5000 shredder that squeals now and then. I have checked all the gears and belts, found no troubles there. I have ran a sheet of lubricant for shredders throuhg the cutters and no change. We...
This a cross cut shredder right? Its job wears out these blades, sooner if not lubricated during its life. Replacing the blade assy. could get costly.
-Carl, please let me know if this helps.
Apr 11, 2009 | Achiever CCS5000 Shredder
I need a manual for my shredder
the overload beeper want cut off and there no paper in it
Aug 27, 2008 | Achiever CCS5000 Shredder
Shredder won't turn on
Has your problem been solved
Please get back to me
Thanks
Jul 07, 2008 | Achiever CCS5000 Shredder
Achiever Shredder CCS5000
Is it on a 20 amp circuit? Check to make sure that it doesn't have a grounding problem or even the plug could be reverse woired.
Oct 10, 2007 | Achiever CCS5000 Shredder
CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Apr 12, 2007 | Achiever CCS5000 Shredder
Achiever CCS5000 Shredder Logo
380 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
