Question about Eclipse CD2000 CD Player
Eclipse deck CD5425
I need to know how to set the clock on this thing, can anyone help me??
  • Mehckat Nov 07, 2008
    thanks alot!!!
Push func on top right then use secod nob (track select) find clock adjust and set
Posted on Nov 06, 2008
Necesito el disco para desbloquear eclipse 5425
Check this link for more details. I can't understand your language, but I assumes that you are in search for a code to your device, and posts this solution.
Feb 14, 2013 | Eclipse New Original CD5425 Remote Control
ECLIPSE CD5425 LOCK CODE
get the serial number from radio and call the dealer and ask for service deparmet and ask them for the code they will ask for serial nmber on radio
Jun 02, 2008 | Eclipse CD2000 CD Player
I have an eclipse cd5425. the unit shuts off as soon as i turn up volume. then comes back on. how can i keep unit on? thank you.
sounds like you have a speaker problem. Disconnect the wiring harness from the eclipse and check the speaker leads with an multi-meter. Each speaker should read something close to 4 Ohms resistance. If 1 or more of the speakers read 2 Ohms or less, the radio is going into protection when you turn it up. You would need to replace the speaker/s. The only other thing I can think of is the power connections. Double check that the yellow and red wires are a solid connection to 12 volt power (yellow=constant, red=switched). Also be sure that the radio's black wire is going to chassis ground, there may not be a ground in the harness or it may be only getting ground through the antenna connection. Good luck
Mar 02, 2010 | Eclipse Car Audio & Video
I HAVE A ECLIPSE CD3412 CD PLAYER AND I CAN NOT SET THE CLOCK
With the unit turned off, hold down the disp (display) button and use 1 & 2 for hr up down and 3 & 4 for minutes up down.
Mar 17, 2009 | Eclipse CD3422 CD Player
How to set clock????????????
sometimes the radio has to be off then hold won one of the buttons until it blinks I'm only answering you because you sound flustered good luck....
Jan 01, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
How do I set the clock on an Eclipse 5332
1) press and hold the display button
2) using buttons 1 thru 4 set the time while holding the display button down. ( buttons 1 and 2 adjust the hour, buttons 3 and 4 the minutes...
Dec 21, 2008 | Eclipse 5440
Eclipse 55430 User's Manual
Here's how to set the clock on the Eclipse 55430:
1. Press the [DISP] button repeatedly to switch to the clock adjustment mode.
2. To adjust the hour, press either button [1] or [2] while holding the [DISP] button down.
3. To adjust the minutes, press either button [3] or [4] while holding the [DISP] button down.
Hope this helps!
Aug 23, 2008 | RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux...
throw it in the trash no good cant reverse
Dec 23, 2007 | Eclipse CD2000 CD Player
Setting the clock on Eclipse cd5405 deck
Push the function button once. turn the right knob (SEL) untill CLOCK ADJ shows on the screen. push SEL in one time to lock in CLOCK ADJ and the hours will blink. Turn the SEL knob to set the hours. push SEL again to get to the min. Turn SEL again to set min.
Aug 29, 2007 | Eclipse CD5405
Eclipse 5340 deck
I forget about the security light but I do know about the clock. I believe you turn the deck off and hold display or push display and the clock will come up. Then use the preset buttons for adjustment. I think 1/2 is for the hour and 3/4 are for the minute. It has been a while for me doing this but I think it is right. I just powered mine back up a while back and am trying to find my starting cd. You wouldn't happen to know how to reset this function and start over?
Apr 11, 2007 | Eclipse 5340
Eclipse CD2000 CD Player Logo
438 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
