Question about LG Televison & Video
I have a lg 50pt85 plasma tv i would like the code for it so as i can program it into the sky remote,ie,to work the sound,and switch the tv on and off many thanks
2 Suggested Answers
SOURCE: setting up 42lg3000 with sky
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Posted on Jan 07, 2009
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - Boards.ie
www.boards.ie > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - boards.ie
www.boards.ie > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from www.boards.ie
Dec 10, 2015 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Lost the remote code for lc-32gd8e for sky
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
also check the below link -
http://www.skyuser.co.uk/tools/remotecodes/index.php
Mar 10, 2010 | LG MW-71PY10 71 in. HDTV-Ready Plasma...
I need the code to program my sky plus remote to my new lg tv it is an lg 42pq300
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
Nov 28, 2009 | LG 42PQ30 42 in. Plasma TV
How do I program my Sky remote to operate my tv
The code is 0206 for Series 6 and upwards Sky remotes.
There is no code for the older ones.
Press TV
Then SELECT and the RED button.
Type in 0 2 0 6 then SELECT.
Boom, your remote should now work.
(Inside the battery cover is a label, it will say which series your is)
Sep 05, 2009 | LG 60PC1DC 60 in. Plasma HDTV
Can't find a code for my ver 6 sky remote for LG50PS3000 TV
on your remote:
TV,
red + select (blinks twice)
TV,
0056,
press VOLUME button if this does not work press TV then repeat
once the VOLUME button works your telly press the SELECT button (stores the code).
If this does not work its because you have a rev 6 remote. take the cover off the battery case and it will tell you the rev number.
I install sky day in day out and ive only had one LG telly that did not accept this 0056 LG manufactor code.
The HD rev 8 remote will work no problem if you follow my steps..
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Tuning the sky remote.
Phone LG service in Slough, they have the info
Oct 13, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
89 people viewed this question
Computer Repairing
Computer Repairing
