Question about Lexmark Office Equipment & Supplies
Lost instructions to install all programs. Not able to use all features.
  • Lexmark Master
  • 1,879 Answers
How to fix a lost photo viewer of windows vista starter
As this is a Windows Feature so u need to look for this in windows feature:
1. Open Add or Remove programs
2. Click on Turn windows features ON or OFF
3. You will see a pop up box with list of windows features, select the option called media features and see if you can find that photo viewer.
4. If you see the name then see if there a tick beside it if not check it and click on ok.
Once its installed you are good to go with this feature.
If you cant find this feature there then re-installation of windows is the best option.
Oct 31, 2015 | Computers & Internet
How do I solve a problem with a Epson printer that wont print because of error messages saying that printer is incompatibke with somthing called ENPAPP
If your enpapp.exe error is related to a specific program, reinstalling Epson Connect Printer Setup-related software could be the answer.
Instructions for Windows 7 and Windows Vista:
  1. Open Programs and Features by clicking the Start button.
  2. Click Control Panel on the right side menu.
  3. Click Programs.
  4. Click Programs and Features.
  5. Locate enpapp.exe-associated program (eg. Epson Connect Printer Setup) under the Name column.
  6. Click on the Epson Connect Printer Setup-associated entry.
  7. Click the Uninstall button on the top menu ribbon.
  8. Follow the on-screen directions to complete the uninstallation of your enpapp.exe-associated program.
Instructions for Windows XP:
  2. Click Control Panel.
  3. Click Add or Remove Programs.
  4. Locate enpapp.exe-associated program (eg. Epson Connect Printer Setup) under the list of Currently Installed Programs.
  5. Click on the Epson Connect Printer Setup-associated entry.
  6. Click the Remove button on the right side.
  7. Follow the on-screen directions to complete the uninstallation of your enpapp.exe-associated program.
Instructions for Windows 8:
  1. Hover the cursor in the bottom left of the screen to produce the Start Menu image.
  2. Right-Click to bring up the Start Context Menu.
  3. Click Programs and Features.
  4. Locate enpapp.exe-associated program (eg. Epson Connect Printer Setup) under the Name column.
  6. Click the Uninstall/Change on the top menu ribbon.
After you have successfully uninstalled your enpapp.exe-associated program (eg. Epson Connect Printer Setup), reinstall the program according to the SEIKO EPSON Corporation instructions.
May 05, 2015 | Epson Office Equipment & Supplies
Need to reset code
Here is an excellent video of how to install, hand, and program the Smartcode 909. It includes switch controlled features of the lock:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Jul 17, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Can't push one button to lock anymore
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
Each time you do this, you toggle between enabled and disabled.
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck-and please provide feedback if this helps!
Aug 12, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security-Keypad Deadbolt BE365
Aug 11, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
Hi does this lock auto lock like the one with a handel does?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage butt0n--Press 7.
Nov 23, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
In need of instructions to operate all features of Microsoft keyboard model KU-0459
hello, the features of the keyboard do not work until the microsoft program for the keyboard is installed on the computer.
you can obtain that program from here http://www.microsoft.com/hardware/download/download.aspx?category=mk
I think this is a comfort curve keyboard 2000.
If you do not know if your computer is 32bit or 64bit, take the 32bit version.
after installing the program and restarting the computer all the features will work, and the program will contain a help document or a manual with it for assistance.
Sep 19, 2010 | Office Equipment & Supplies
I have an AT&T Partner 18D phone and lost the instruction manual. How do I change the time?
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Nov 10, 2009 | Lands Phones
Lost the program Vesta
you can download vista from a bittorrent site and use the product key from the bottom of the laptop
Jan 17, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
