Question about Soundstorm D400.2 Car Audio Amplifier
Amp automatically goes to protection mode
I recently hooked up my SoundStorm D400.2 amp and it wouldnt work. Every time i plug in my RCA jacks it went to protection. I had it hooked in there before and didnt have a problem. I'm stumped and dont know what to do. PLEASE HELP!
  • Troy Shafer Sep 30, 2006
    I forgot to add that it does this whether my remote turn-on is connected or not.
Clean chassie ground just like battery terminals
Posted on May 14, 2007
    Problem Solver:
  • 6 Answers
Bad Ground.
Posted on Nov 02, 2006
Gos in to protection mode as soon as you aplly power
Check for a short circuit in the wiring of the output speakers or a shorted speaker voice coil, also check for correct voltage to the POWER AMP while in use... when an AMP goes in protective mode this means two things A SHORTED OUTPUT or A INCORRECT VOLTAGE TO THE POWER AMP. if all the above is OK than the AMP is defective. are you using correct speakers OHMAGE 4, 6 8ohms??? according to your AMP.
Feb 17, 2011 | Soundstorm Force F2800 Car Audio Amplifier
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Amp went to protect mode and will not reset to green.
Be sure the rca's are not getting severly pinched or worse you drilled a screw into them.
Second make sure your connecting the RCA's to the
1. OUTPUT of the radio
2. INPUT of the amp
if you connect any other way its wrong and could damage both radio and amp especially you screw into the RCA's your sending 12 AC Volts to ground.
Apr 06, 2010 | Swiss Audio SMX-4400C Car Audio Amplifier
FUC% the protection light
i had a similar problem with my amp (although a different brand). Check you ground connection and make sure it's not grounded to metal with paint covering it. This is NOT a solid ground connection. You must remove the paint then reconnect it. Without a solid connection to ground, it cant run for very long without going into protection mode. Hope this helps
Jul 27, 2009 | Soundstorm Force F2800 Car Audio Amplifier
Can u help me
The amp probably has shorted outputs. Do you want to try to troubleshoot it and repair it yourself?
Nov 22, 2008 | Soundstorm D500.4 Car Audio Amplifier
Car amp
seems like the rca jacks are loose on the inside of the amp
Jul 04, 2008 | Car Audio & Video
Aux input on Soundstorm amp
If the amplifiers have RCA jacks, you can use an adapter cable to go from the headphone jack to the RCA inputs on the amp. If you're in the U.S., Radio Shack will likely have what you need.
Jun 30, 2008 | Soundstorm 2F400 Car Audio Amplifier
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
Soundstorm 1600 Watt Car Amp
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 14, 2007 | Soundstorm D400.2 Car Audio Amplifier
Soundstorm D400.2 Car Audio Amplifier Logo
174 people viewed this question
Top Soundstorm Car Audio & Video Experts
hoyzee1
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
