Question about Bugaboo Cameleon Jogger
Bugaboo Hand Brake Mechanism
We have just puchased a second hand Bugaboo Chameleon and the hand braje won't lock.
I have removed the mechanism and the inner plastic ratchet is broken, any ideas about where I can get a new one?
thanks
jon ......
  • 1 more comment
  • nlscooby Nov 05, 2008
    Mine is brand new and the brake seems to be highly sensitive when locked. If I put any pressure on the handle, it unlocks itself - which is not a safe feeling!
  • rstehling Dec 02, 2008
    My cameleon brake is auto-unlocking also... My baby has not yet been delivered, so I had not tested with a baby on it....
  • Daddy Bear Dec 28, 2008
    Our brake got broken on one side whilst in the hold on a plane. It's over 2 years old now.. Not sure what to do. The brake holds on the flat but on a slope it rolls round...
I have easily solved this problem here in Brazil, where there are no Bugaboo retailers or assistance. I just opened the brake lever case by unscrewing it and fixed the white piece in its correct position. It's very easy to figure it out.
The only special care you have to take is not to lose the spring that is inside it.
I've read the solution here in this site wherelse.
Posted on Dec 10, 2008
  • 13 Answers
The right thing to do is to contact bugaboo they should solve this problem by sending you a new chasis if it is under 2 years old if not you can purchase a new chasis at a near by retailer they can order one for you here is bugaboo's number 1-800-460-2922
Nathalie
I have a bugaboo cameleon 1st generation that has a fault. If i was to buy a new 2nd edition chassis would my carrycot still fix on to this chassis.
I have a second hand chameleon and it feels like the frame is a little loose. Is there any way that you could tighten the frame up?
May 10, 2011 | Bugaboo 'Cameleon' Stroller
Bugaboo chameleon stroller won't collapse
hi there go to www.buggypitsop.co.uk they do repairs to bougaboo and other pushchairs.
Dec 19, 2009 | Bugaboo Cameleon Stroller
The brake button on my bugaboo chameleon is jammed and won't release therefore the brake won't work , what an i do
Your best bet is to contact www.bugaboo.com for a brake assembly replacement. If the break is permanently in the 'on' position, then gently push it forward (as if to put in on) whilst pushing the white release button, this should release the mechanism. If this is still within it's warranty, see your retailer for help.,
I hope this helps.
Sep 01, 2009 | Bugaboo Cameleon Jogger
Chameleon: brake not secure and extendable handle lock jammed
This has been solved elsewhere on this site - do a search, but spell Cameleon without the H in it and you'll find it
Aug 31, 2009 | Bugaboo Cameleon Jogger
Bugaboo cameleon
Based on what you have described, it sounds like the silver domed cover (where the handle meets the bottom of the chassis) may be damaged, this may mean a new chassis is required.
I would suggest that you contact your retailer for repair advice (if this is still within the warranty period) or contact Bugaboo directly on the website link below:
www.bugaboo.com
Please note that you will need to have your chassis serial number to hand.
I hope this helps.
Jul 02, 2009 | Bugaboo Cameleon Jogger
I want to change brake pads on my 03 Mazda Protege SE. What is best way to release hand break cable from caliber, remove caliber? This is the first set of breaks for this vehicle, but I've replaced pads on...
Some calipers have a bolt holding the hand brake mechanism to the body of the caliper. hold the mechanism with a spnner or If yours dont simply lever the mechanism with a bar or long screw driver. Place a pair of lock pliers/ mole grips on the cable(not too tight or you'll fray/damage the cable) then remove the cable from the caliper. When you get the pads out use a screw driver or wind back tool to reset the caliper travel or you will damage the caliper or lose the hand brake altogether.
May 12, 2009 | 2003 Mazda Protege
Bugaboo Hand Brake
the only way is to call directly to bugaboo because these are inner problems that have to be fixed (if it can) if the stroller is more then 2 years old you might have to go to your nearst retailer and order a new chasis for i it (there around 100.00 to 200 dollars. if you need the exact amount let me now and I can get it for you tomorrow the number for bugaboo is 1-800-460-2922 good luck
nathalie
Dec 01, 2008 | Bugaboo Cameleon Jogger
Main Chassis bar won't lock on one side
We had a similar problem, the right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Ben
Aug 28, 2007 | Bugaboo Cameleon Jogger
Brake does not engage
the brake disengages using the button. if it is forced the mechanism slips. its fairly straightforward to take it apart with a screwdriver. clean the plastic parts, put it back together right and screw it back on. then all you need to do is show granny how to work it (again) to prevent it happening again.
Jan 30, 2007 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Jogger Logo
781 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
