Question about Brother DCP 115C All-In-One InkJet Printer
'Unable to clean' problem with Brother DCP-115C Printer
I was told by Brother that 'Cannot Clean' (fault 460) means that the absoption pads needs to be replaced. Their sponsored engineer estimated a cost of about £80 to replace the pads although the 14 months old machine only cost £40 new and was used about 12 times. I have now acquired new absorption pads for the Brother DCP-115C printer.How can I access the old ones on the machine and reset the purge counter? Thanks R. Forde chaz_forde@yahoo.co.uk
    Genius:
  • 1,250 Answers
Download the canon resetter utility - IP utility http://www.ipt.nm.ru/ you will have the solution
Posted on Nov 11, 2008
  • jiangxing123 Dec 09, 2011
    authentic nfl jerseys Inexpensive
    coach bags on sale Very nice
    coach outlet store online single product
    coach outlet online on sale
    coach bags outlet High quality
    coach outlet store Very stylish
    wholesale designer bags brand loud
    coach bags outlet great collection
    cheap coach style a lot
    wholesale nfl jerseys Bought a lot
    authentic nfl jerseys force promotion
    President:
  • 1,952 Answers
Pull out the AC plug
- put back the AC plug while holding down the �menu� button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and �error 46� pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
The only remark is that your waste ink box is too full with ink. Ink flooding might be happening
machine error 46 means that your printer's purge unit has reached its counter limit and needs replacing, the reason i say this is because your machine has done alot of work and parts will be warn in your m/c, if you just reset the counter you will end up with ink througout your machine, normally when your printer is up for a purge unit its better to get a new machine with new cartridges and a 12 month warranty and no wear. u can get the new brother for about $79 wich is by fare a way better way to go. and with the new brother the inks are alot cheaper than earlier models wich is a bonus.
you the reset procedure for the m/c and pruge but just doing a reset will not cure this problem you need to replace purge unit and do a counter reset on your purge unit, (used to clean the printhead) thats why it says unable to clean,
Posted on Jan 28, 2009
  • mohammed marika thambi
    mohammed marika thambi Jan 28, 2009
    The machine counts all purge (cleaning) operations in order to prevent
    the internal ink absorber box from overflowing with purged ink. An
    �initial purge�, for example, advances the purge counter by 187 + 420 =
    607. When the purge counter approaches 6400, an internal "Machine Error
    46" is generated. Further purge operations are prohibited, and
    therefore the printer becomes unuseable.
    When an internal
    Machine Error 46 is generated, the user will see an �Unable to Clean�
    external message and will be unable to use the printer. The �Unable to
    Clean� external message can relate to many different internal error
    codes however.
    The user can establish the internal Machine Error
    Code as follows: pull the mains cable out of the machine (power off),
    hold down the Menu/Set key, re-insert the mains cable into the machine
    (power on). The internal Machine Error Code will be displayed.
    If
    there is a Machine Error 46, it is necessary to dismantle the printer,
    replace the ink absorber box (or possibly break the ink absorber box
    open and clean its absorbent sponges under a tap), re-assemble the
    printer and reset the purge counter to zero.
    Solution no. 1. (DCP-110C / DCP-115C / DCP-120C / DCP-130C):
    The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
    1.
    press buttons Set, Menu, Mono Start one by one, followed by up arrow
    key four times. this should all be done as short a time as possible,
    around 3 seconds.
    2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
    3. press up arrow key several times to get to the Purge item
    When an internal
    codes however.
    If
    1.
    around 3 seconds.
    . enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
    5. press Stop/Exit key to go to root of maintenance mode
    6. enter 9,9 to exit maintenance mode
    Solution no. 2. (DCP-110C / DCP-115C / DCP-120C / DCP-130C):
    Here's how...
    1. Pres 'menu', 'mono start' then 'menu' one by one...
    2. Press the arrow up or down to go to 'maintenance 80'.
    3.
    Press 'mono start' several times to go to 'Purge'. Finding the PURGE
    will show some numeric value which is I assume the number of times the
    printer had cleaned.
    4. Press 'arrow up' key and scroll for
    number "2" then press "set". Do the same for numbers 7, 8 and 3. After
    you have entered this combination, the purge numeric value will be
    reseted to 00000.
    That's it...
    Solution no. 3. (for printers with numeric keypad):
    Resetting purge counter on: MFC-620CN / MFC-420CN / MFC-410CN / MFC-210C and FAX-2440C:
    1.
    Enter machine maintenance mode (on MFC-210C all four
    photo/copy/fax/scan lights flash in maintenance mode). Care is needed
    in maintenance mode, otherwise critical settings may be inadvertently
    corrupted.
    FAX models with numerical keypads: Press the
    Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to
    complete the correct key sequence within two seconds, press the Stop
    key to try again).
    Other (non-FAX) models: Press the Menu/Set
    and Black Start keys. Next press the �up arrow� key four times to enter
    the maintenance mode.
    Press the 8 then 0 keys in the initial stage of the maintenance mode to
    call up the machine's log information list (function code 80).
    3.
    Press the Black Start key several times to scroll through the log
    information list to reach the purge counter. The purge counter is the
    25th item in the list.
    4. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
    5. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
    6. Press the 9 key twice to return to the standby state.
    Brigadier General:
  • 6,966 Answers
To my knowledge, the waste ink absorption pad would be directly underneath the ink cartridge holder/print head assembly when at rest (parked). The carriage would have to be moved away from the rest/parked position to gain access. You would need preferably a pair of tweezers to lift out the old pad and replace with new.
As to the "reset the purge counter", pls try:
  1. press the Menu & Mono start keys. next press the up arrow key 4 times to make the machine enter the maintenance mode.
  2. Enter 8 & 0 by using the up arrow key & SET keys.
  3. press the mono start key several times untill the purge count appears on the LCD.
  4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
  5. press the stop/exit key to return to the initial stage of the maintenance mode.
  6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
Above steps should be performed as a continuous and smooth key entries with no pauses.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • 2 more comments
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
  • Louie  Role
    Louie Role Jan 28, 2009
    Hi and welcome back.
    Appreciate the update. A detailed procedure on how to remove and replace the waste ink absorption pad is described here. Unfortunately it is not in English. There are pictures/illustration though to guide you. Should you want an English translation, copy the link in a Goggle search box, click on Search and it would appear as first among the choices. Rather than clicking on it, click on the "http://www.hstt.net/refill-faq/inside.ht...">Translate this page".
    Again thank you for coming back to FixYa.
  • Louie  Role
    The engine design is similar to your model.
  • Louie  Role
    Were you able to view the instructions from http://www.hstt.net/refill-faq/inside.ht..." target="_blank" rel="nofollow" >here?
  • Brother Master
  • 19,396 Answers
If you used the machine only 12 times it is impossible that you have a 'Cannot Clean' (fault 46, not 460) because the absorption pads needs to be replaced.
The absorption pads needs to be replaced after the machine has done at least 2000 copies or more, depending on the usage.
This problem is not even related to a printer counter in need to reset, this if the fact that the machine had been used 12 times is true.
Try unplugging the machine first.
If this does not reset, do the following:
Enter in service mode, by unplugging power cord, then holding down Menu/Set key, while you plug back the power cord at the same time (be careful doing this)
The diagmnostic mode will display an error code, if it does not , then the machine is OK.
If there is still the error code:
Use the down key until you get Purge Counter on the menu.
Press the combination of keys 2, 7, 8, 3. This will reset the purge count.
Press the Stop or Exit key to return to maintenance mode main menu.
Now press twice key number 9 to return the printer to the original mode.
If the printer is stuck in standby then unplug main power again.
If this cannot fix the problem there is an internal fault that is probably not related with waste ink tank and absorption pads.
Normally the reset should purge the print counter, and get rid of the problem.
Posted on Nov 03, 2008
    Genius:
  • 1,550 Answers
Dismantle the printer, replace the Absorption pads .
Enter machine maintenance mode.
Press the Menu/Set and Start keys.
  • Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list
  • Press the Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
  • Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
  • Press the Stop/Exit key to return to the initial stage of the maintenance mode.
  • Press the 9 key twice to return to the standby state.
DCP 185C ERROR 50
Sir/Madam
I Suggest You To Watch Clear Error 46 Unable to Clean on Brother Printers Without Number Pad To Fix Your Brother Printer Issue,In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jan 21, 2014 | Brother DCP 115C All-In-One InkJet Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
My DCP-115C printer was missing red colour.
Yellow is one of the colours used to produce a shade of red.
I don't know how but ther must be a way to print a test page to see if the print heads need cleaning I've never used a brother.
Sep 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Printer unable to clean
the printer has a counter for the supposed amount of ink the absorber pad can absorb.
i have reset the counter using the following and now it works. In theory you need to get a replacement pad but i haven't been able to find one yet. My printer is now working fine
following is the solution to reset the counter for the old fault
> Brother DCP110c Reset Counter
> 1. unplug at side of unit, switch on while pressin menu2. Enter 8 press
> set enter 0 press set
> " by using the up arrow key & SET keys."
> on the LCD.
> purge count to zero (like in 1)
> maintanance mode.
> 6. enter 9 twice by using the up arrow & set key’s to exit from
> maintenance mode
Michael
Mar 06, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean problem
turn the rpitner of then check there is not any paper jam.
also refix crtridge after clean it.
Jan 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C USB Printer
plz search this forum for error 46 or "unable to clean". It has been written many times ;-)
May 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
May 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
860 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
