Question about Samsung HCM4216W 42" Rear Projection Television
TV turns on with no picture or sound
When I turn on the TV, the light indicating that it's on turns on, but there is no picture or sound that shows up. What do I do??
  • 3 more comments
  • hzcarz Jan 30, 2008
    same problem. i can hear the set power up but nothing happens except the timer light is blinking
  • Anonymous Mar 01, 2008
    same problem!
  • Anonymous Mar 20, 2008
    Same problem as the rest, red light blinks, no picture or sound
  • yhayes Mar 25, 2008
    TV simply will not turnon ... I can see a bit of light around the on switch ... but nothing ... no electronic melody ... no sound ... no picture. .... just didn't come on in the AM.
  • JonRoss Apr 01, 2009
    if anyone knows how to fix that problem let me know
    mistabonesdead@yahoo.com
Same thing... Sounds like it is pretty common problem.
Posted on May 18, 2008
Mine does the same thing, just unplug it for about 2 minutes and it should come back to normal again.
Posted on Jan 31, 2008
Atechnichian advised me that when that happens it means that one of the projection tubes overheated from leaving the tv on too long and leaked on to a pc board he said the tv is not worth fixing
Posted on Nov 06, 2007
SOURCE:
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
No picture, no sound, indicator light on then goes into flashing
micro chip problem it is damage.have a tech look on your set for repairs.good luck.
Feb 28, 2010 | JVC 47 in. LCD TV
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Toshiba HD TV Model # 42HL117
Toshibas are notorius for Sustain board failure, You will have to find qualified servicer thru craigslist or yellowbook. If this is your problem, you could see a repair bill of 400+
Craig Cleveland Classic TV www.classtorations.com
Jun 08, 2008 | Toshiba Televison & Video
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Samsung HCM4216W 42" Rear Projection Television Logo
120 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
