Question about Panasonic Lands Phones
Re Panasonic digital phone KX-TG6071B We have no messages on the answering unit but it tells us that the memory is full. We have deleted messages, shut off the power, etc. but it still tells us that the memory is full. Stephen Walker
5 Suggested Answers
  • 2460 Answers
SOURCE: How to record miscall on Panasonic kx-t7730
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Posted on Sep 22, 2008
  • 2460 Answers
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Posted on Oct 01, 2008
SOURCE: Panasonic KX-A144ES
Press Int then # then *5
Posted on Dec 16, 2008
SOURCE: how can i check my
how do I retrieve messages when I am away, and how do I change the code to get messages?
Posted on Aug 14, 2009
My KX-TG2322 takes neither incoming messages nor outgoing ones` it says 'Memory Full', although no message is there.
Erasing all messages
All recorded messages, except the greeting
message, can be erased at one time.
1-Press [ERASE] while the base unit is not
being used.
• "To erase all messages, press ERASE again" is
2-Within 10 seconds, press [ERASE] again.
• The unit beeps, then announces "No
• The base unit display shows "0".
Mar 08, 2015 | Panasonic KX-TG2322B - 2.4ghz Digital...
Three of the five hand sets just went dead.
Must be some hardware problem. Contact Panasonic showroom.
Feb 09, 2014 | Panasonic KX-TG6071B Cordless Telephone...
My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
The manual for the phone is available here: .
I hope this helps.
Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
Answer device memory full - unable to erase any messages
Dial 1571 that should take you to the message centre. There you have the option to delete/clear messages.
Any further questions please ask.
Nov 19, 2010 | Panasonic KX-TG1034BP Quad 1-Line Cordless...
Need to retrieve lost or deleted message.
As a Expert that is not going to happen once these messages are deleted there gone for good, Even a data recovery center would not be able to help unless it was store on a magnetic tape of some sort.
What you got in this machine is NV-RAM Non voltile RAM random access memory. Meaning once the unit looses power or messages where deleted that area can no linger be accessed.
Hate to be the bad news breaker here makes me feel bad. But please show you support and leave a postive feedback and rating for your free answer today.
Jul 01, 2010 | Panasonic KX-TG2740S Digital Answering...
Using the fax machine of Panasonic KX FT981, how can i add a contact (including its number) into the phonebook ?
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
Feb 24, 2010 | Office Equipment & Supplies
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Lands Phones Logo
70 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
