Question about Panasonic CT-32G11 32" TV
Tv is completely dead
Hello, I was watching tv, when I went to change the channel the tv just went completely dead. It does not seem to have power going to it yet everything else on the same power strip does. This is pretty annoying seeing as though the tv is only 10 years old. Your help is appreciated in solving my problem. Thank you jsetter
  • Joyce Setterstrom Oct 01, 2006
    Thank you Techman, your answer was what I expected. I did send the TV out to a technician.
    jsetter
    President:
  • 3,130 Answers
Only 10 years old??? Ok its most likly at the end of its usefull life, unless you want to put some cash into the set, as there are no user replaceable parts inside this TV, so you really should let a trained tech estimate it for you. But once you fix it, you most likly will start have problem after problem. Do yourself a favor, and buy a new one. The problem with this set is most likly the flyback and other componets or the power supply capacitors are bad.
Posted on Sep 30, 2006
Alba 32inch hd lcd tv
The internal power supply may have failed.
Nov 14, 2013 | Televison & Video
While watching the TV the screen went blank and there wasn't any sound. I've checked all the cables. I tried turning it off and back on but when I did this the power light flashes 27 times before...
The tv power supply board it is shorted and dead.That the board where the tv power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 28, 2011 | LG 32LC2R 32 in. HD-Ready LCD Television
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sharp 27F-630 27" TV
Dear eligas1312, Most probably your antinna is not reciving TV signals properly.Try to adjust it in a right direction at a proper height, also adjust frequency of various channel of Direct TV through menu button. regards ajay
Aug 04, 2007 | Sharp 27F-630 27" TV
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
