the oven knobs have burn with the grill cant see the oven symbols noe on dail can you give me help or send the symbols to me the oven knobs have burn with the grill cant see the oven symbols noe on dail can you give me help or send the symbols to me
You can't post conmments that contain an email address.
Fan symbol - defrost (fan only - does not use thermostat) Fan symbol within a circle - fan forced oven 3 little triangles - static grill (keep oven door open) 3 triangles above the fan symbol - fan grill (keep door closed)
the first knob has tree positions in the middle is off to the left the top (grill) heats to the right top (grill) and bottom heat, the second knob indicates the temperature in the following way ..50....100....150....200....250..good luck
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
0 = Off
Lamp symbol = Lamp Only, no fan, no heating.
Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
