Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore Side by Side Refridgerator
I have a 5 year old Kenmore fridge that keeps clicking. the clicking noise is on the lower righthand corner(if standing in front of fridge or lower left if in back). any thoughts on what this could be?
  • 1 more comment
  • mules24 Nov 06, 2008
    Yes the compressor is working. the fridge is pretty much doing what it's suppose to do. after listening to it further i think it click when the compressor goes on and when it goes off. sometimes it's really quick and sometimes it's like 5-10 minutes.
    the fridge is cool and the freezer is cold so it seems to be making it's temp. the coils might still be dirty, i did some vacuuming this past weekend. what about the start relay? could it be that? or is it a bad compressor?
  • RAP13514 Feb 15, 2009
    I have this problem as well. There is a click, then an electical hum sound for about 4 or 5 seconds followed by another click. This happens frequesntly throughout the day. Both frige and freezer seems to be working fine but I know it's only a matter of time. Anyone know what this could be?
    Genius:
  • 1,122 Answers
It sounds like the compressor is short cycling,is it working at all?mike
Posted on Nov 06, 2008
  • MIKE major Nov 06, 2008
    is the frig. making temp.? are the coils dirty?when you hear a loud click it is the comp.trying to start but it can't,let me know more-mike
Kenmore elite refridgerator
check to make sure door is not stuck shut... or food may be blocking door outlet (usually located upper left hand corner of fridge side
Aug 29, 2014 | Kenmore Refrigerators
My refridgerator smells like fermented oranges. the smell is now in the water from the fridge and tastes like the bad smell. fridge is a side by side maybe 5 years old, don't know the brand right now....
This may be from the dirt that has accumulated on its drain or inner panels. Clean out the unit. In that way you can inspect the insides. Clean out every corner and drains. Make sure you check the coils at the back of the fridge. You will have to unscrew the panels inside to get to it. Check if there are balls of ice forming on the coils. There may be a leak, and the smell may also be from the freon.
May 10, 2011 | Refrigerators
Our refridgerator is old
in the toe kick
or in the upper right corner of the fridge
Oct 03, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Refridgerator has power but does not get cold
Can you tell me if you hear the compressor running under the refrigerator? Is fan running beneath the refrigerator? Need to get the exact Kenmore model number found when you open the fresh food section. Let me know, Sea Breeze
Mar 19, 2009 | Kenmore Refrigerators
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
212 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
