Question about Dishwashers
How do I reset a zanussi dishwasher
Dishwasher ( Zanussi ZT 695) has frozen during a program. Green on light and the program light are on
  • 641 Answers
SOURCE: zanussi dishwasher DA 6141 6 years old
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Sep 02, 2007
COXY
  • 76 Answers
SOURCE: Zanussi Dishwasher DE6850
Sounds like a heater problem to me, does it go through the complete cycle on its own?
Posted on Dec 03, 2007
Trifect7
  • 57 Answers
SOURCE: dishwasher zanussi zsf 6128
Either it's not getting enough water to flip over to the next part of it's cycle (unlikely) or the water float gauge is not working properly.
When the dishwasher is cool, look for the float inside the dishwasher --usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring loaded). Lift out the float mechanism and clean around the float tube; many floats must be disconnected from below--to do this you'll have to remove the lower access panel. Rinse off the float, then replace it in the tube and be sure it moves up and down freely.
If you're experienced with minor repair work shut off the hot water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel, disassemble the valve to reveal the screen, clean debris from the screen, and reassemble. If the screen doesn't appear to be blocked, call a repairperson (they will probably need to replace the water intake valve).
If none of this helps, call a repair person. Any of several parts, including water inlet valve, pressure switch, and the timer or selector switch, may be faulty.
Posted on Mar 02, 2008
SOURCE: zanussi ls9 dishwasher
check your boiler,maybe there is no water there
Posted on Aug 03, 2008
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My Zanussi DE 4544s dishwasher has this fault, when you put any cycle on it reverts to the flashing green lights......any help would be much appreciated.
You need to go on line to the Zanussi web site and request the error codes for this machine. Once you know what the problem is you can pose a question!
Dec 31, 2012 | Dishwashers
Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Dishwashers Logo
211 people viewed this question
Top Dishwashers Experts
