Question about Lexmark X2470 All-In-One InkJet Printer
Piece to hold in ink broke
Can i order piece that holds the ink cartridge in. It broke with no effort when replacing ink cartridge?
  • Anonymous Feb 14, 2009
    SUCKS! 1st time changing the cartridge and the piiece breaks! JUNK!!
    Lexmark X2470 DON"T BUY
  • Anonymous Mar 09, 2009
    same problem
Went to lexmark.com and chatted with agent , he said i had to replace entire printer. they don't make spare parts! isn't that a bunch of ****!!!
Posted on Nov 04, 2008
I broke the green plastic piece off that holds the ink in my sharp ux b700 fax machine where do i get a replacement
Take your ink out of the fax and clean the broken part with alcohol and then just super glue the piece in, it does not have to hold any weight, so you shouldn't have any problem with it if it just holds the ink. Super Glue and plastic work great together.
Mar 19, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Plastic piece in front of the cartidge prevent cartridge removal
Please have a look at this support tutorial. I think you will find that the plastic piece is the cartridge latch which holds the ink cartridges in place.
HP DeskJet 6988 Replace Cartridge
Jan 09, 2010 | HP DeskJet 6988 Printer
A piece of the plastic that holds one of the cartridges in place broke. I now keep getting printer cartridge failed. Can I get that little piece replaced??
Hello. If you have that little piece you can reattach it with some clear one minute epoxy. Just do not over do it with the epoxy so you don't end up doing more gluing that you need to do. Other wise you can order parts for your printer. Just go to the following link and order what you need directly from HP
http://h20141.www2.hp.com/hpparts/CountryChoice.aspx
Regards, Joe
PS please rate my answer. Thank you and happy holidays.
Dec 26, 2009 | HP PhotoSmart 7350 InkJet Printer
I have an HP Deskjet 6540 which I have owned and had no problems with for 2 years. Yesterday I replaced the ink with new hp ink cartridges number 96 and 97. However, the printer is not working and the icon...
When the carriage is worn out it doesn't hold the ink up to the contacts inside. If you remove the ink and place a small piece of paper behind the connector inside it will move the contacts out to the cart. Also try a piece of tape on top center of cart to hold cartridge in to the contacts better.
Oct 29, 2009 | HP DeskJet 6540 InkJet Printer
Officejet d135 says bad black printhead- Replace the pentagon --
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | HP OfficeJet D135 All-In-One InkJet...
Replace ink comes up, just replaced that color, can't be empty
Aug 24, 2009 | HP Photosmart C6280 Printer
Piece that holds in the ink cartridge broke i need a part where
HP doesn't stock any of those small plastic pieces for us to order. The best bet is Ebay or garage sale for a scrapped printer.
Aug 11, 2009 | HP PSC 2175 All-In-One InkJet Printer
The printhead has a problem (after replacing the yellow/black ink cartridge with HP ink).
Try to clean the printhead manually ,
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Broken the bottom print cartridge holder - blueish gray
The part has been broken in my printer for over a year now. I hold the cartridge in with a rubber band.
Apr 08, 2009 | Lexmark X2470 All-In-One InkJet Printer
Can I replace the PSC2210 print cartridge hold down lever?
The entire unit which holds the cartridge needs to be replaced. get it dont by some local tech shop.
Thanks
Nov 26, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
