Question about Car Audio & Video
2003 td6 amplifier
I have a tremendous amount of static intermittently coming through the speakers, whether the radio is switched on or off. I am told its the amplifier in the luggage compartment in the back. Can it be repaired because i am struggling to find a second hand one.
    Problem Solver:
  • 7 Answers
Rca's usually or bad ground, power wires,(crossed) (getting static electricity) seems to be alot of stuff going on...
Posted on Nov 06, 2008
Have a set of speakers home 120W/channel that very often let heard through them very annoying static. Have use others amplifiers: hasn't done one single change. Static seem to come from tweeters.
Static electricity could be causing the static . It's possible the way they were soldered together That's what I was told so I got sick of the static and gave my old ones away and got another set of speakers. They work fine. Was also told it could be the plug ins for my amp as well not being tight enough.
Jun 23, 2017 | home Audio Players & Recorders
2006 2.0l diesel. Why is there an intermittent beeping sound coming from passenger door speaker?
Could be bad speaker, bad wire pinched in door hinge, the radio could be bad, or there could be some RF interference the wire is picking up. Try switching speaker around.
Jul 31, 2015 | Volkswagen Passat Cars & Trucks
How do I disconnect the amplifier on my 2005 Grand Prix; it makes continuous static noise whether the radio is on or off or whether the ignition is on or off?
Assuming it's the monsoon amplifier it's located under the rear deck about 8 inches away from the passenger rear speaker. However unplugging it will kill all the speakers. The only way to properly bypass it is to run all new wires.
You maybe able to find another factory amp at a salvage yard.
Warning: Most of the Monsoon head units have a 6V offset, making it incompatible with aftermarket amps.
Feb 28, 2015 | 2005 Pontiac Grand Prix
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
On my 2003 Avalanche, after the radio has been on for a few minutes static starts in the front right speaker then travels to all of them. As the static gets louder the radio volume goes down and the static...
take out the speaker in question and test it.
a 9v battery is good enough to 'burp' it.
if it makes a scratchy noise when you put power to it then you have a short in the voice coil.
Burping a speaker is just a short power up. Don't hold power to it.
Tap it on and off like a music note measure.
Apr 16, 2017 | 2003 Chevrolet Avalanche
My 2003 ford focus radio is a blackpun it turns on but no sound come thru the speakers can someone help me
A Blaupunkt? Verify that the speakers are connected to the radio. This is simple if they are directly connected, but if they are connected through a power amplifier, then things get a little more complicated. If there is a power amp, then you might want to try connecting a speaker to the radio directly first, to help determine whether the problem is with radio, amp, wiring, or speakers.
Aug 24, 2010 | 2003 Ford Focus
MY FACTORY RADIO VOLUME PROBS
More than likely with a 2003, the speakers that cut out are in the door or doors. Do they cut out of both speakers?
If they cut out of one, then you may have an intermittent speaker ( the wire to the cone becomes partially connected)
If both speakers turn off at the same time and you hear NOTHING on all speakers, then you more than likely have an intermittent connection on the radio itself and probably replacement is probably cheaper than fixing the radio.
One more thing
Factory radios sometimes have an amplifier in them. Sounds funny but they call the Radio in the dash the Head Unit and the amplifier is buried in the dash. You could have a bad amplifier or a loose power connection to it, but that is very unlikely.
Hope this helps.
E
E
Mar 02, 2009 | 2003 Chevrolet Silverado 1500
Speaker noise in car at all times
I replaced the amplifier that was mounted under the passenger seat it had gotten wet after the convertible top failed during rain storm
Nov 27, 2008 | 2003 Mitsubishi Eclipse Spyder
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Pioneer VSX 816
The rear signal is generated and separated internally, if either the processing is not correct or the rear channel amplifier has a problem, you can get this type of behavior. Does the static happen more often at higher volumes or is it purely random? Does changing the volume make the static louder or is it always the same level?
Dan
Mar 18, 2008 | Pioneer VSX-816-K/S Receiver
Car Audio & Video Logo
135 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
