Question about Toshiba 57H83 57" Rear Projection HDTV
Autofocus My autofocus does not work. When I push the button it initially appears to be working as the red and green lines come up and move around. Then the screen goes black and an error message comes up.
    President:
  • 3,130 Answers
There are two IC's in your set that need to be replaced. These are convergence IC's. They have stk letters and some numbers on them and they stand up on a metal heat sink. If you know how to unsolder and solder on solid state printed circuit boards then you can replace them as long as you are carefull. These solid state sets are really super unforgiving if you slip and touch or short something together as there is still voltage in them even when they are unplugged. if you havew no electronics training, I would recommend that you seek out a trained tech to repair this set for you. It should not exceed more the a few hundred bucks and some peeps do it for even less.
Posted on Sep 30, 2006
SOURCE:
I can't find object in dark. Though the camera should identify (may be red ray focus) the object to take snap. In manually I set up all the possible way but in vain. Could you pls. give me a set up...
Yes, the camera does attempt to illuminate the area to allow autofocus, but the darker it is, the harder it is for autofocus to work. This is a problem even with high-end SLRs.
Usually the center focus point is the strongest and focusing works best when there is a strong vertical line.
There isn't a complete solution, but you there are a couple of work-arounds If you have a camera with manual focus, then use manual focus Point the center focus point on an edge, depress the shutter button 1/2 way to focus, then re-frame the picture.
Mar 03, 2011 | Cameras
My tv has red and green lines going through it..does this mean its broken? And is there anyway of fixing it?
This is the autofocus circuit or known as the convergence circuit. The circuit could be out of adjustment, or simply failed completely. You can check that any autofocus is not working for the menu images, or check that the autofocus is off, and turn it back on. Otherwise you need to change this circuit or try adjusting the screws to see that you can bring it back to focus yourself.
Oct 26, 2010 | Hitachi 51F500 51" Rear Projection...
Autofocus
Reset.
Press and Hold the INFO button near the trigger and 'I' button at left side bottom for few seconds. Once the information appears on the LCD screen, your autofocus should be working.
Orelse, carry it to an authorised service centre.
May 14, 2010 | Nikon D5000 Digital Camera
I have an Olumpus d-535 camera that does not Autofocus well.
Try pushing the Shutter halfway down until you get a green "go" indication, and take the pic. This forces the camera to focus, and is something you often have to do with these point and shoot automatic focusing cameras.
Mar 13, 2010 | Cameras
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Oct 11, 2009 | Nikon D300 Digital Camera
Autofocus is not working
Out of the box, I couldn't get a center focus shot. Out of desperation I reset the camera (push info and magnify buttons at the same time). That solved the problem.
Jul 27, 2009 | Nikon D40x Digital Camera
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Autoocus doesn't work
The first thing to check is that autofocus is enabled on the camera body.
The auto/manual focus selector switch is located on the front of the camera, just below the lens release button (on the left side as you look through the view finder). Make sure that the white dot on the selector lines up with the white dot under the AF (autofocus).
If this does not solve the problem, make sure that your lenses are set to autofocus mode as well.
Dec 25, 2008 | Nikon CA-1104-SMK for D70SLR
Fe 230 focus problem
the LCD may not light at the first due to low batteries too... but i feel there are some more problem... as the shot is also blur you can try cleaning your lens... the autofocus may not work due to dust also... try cleaning the lens of your camera
Oct 23, 2008 | Olympus FE-230 Digital Camera
Convergence
You need a remote that can produce the "DISPLAY" button on the Sony remote in order to get in service mode....(you could also carefully move the centering rings on the red CRT to line it up with the green CRT)
Jul 17, 2008 | Televison & Video
Toshiba 57H83 57" Rear Projection HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
