Question about Packard Bell Computers & Internet
Hi, when I press the on button, the machine springs into action but immediately starts a ticking noise as if something is stuck. The blue light on the switch flashes in time with the ticking. It doesn't get as far as showing anything on the monitor. A friend told me (as did a PC World Tech Guy - although only from my verbal description) that my hard drive was knackered and that something had physically broken inside the hard drive. I bought a new Hard Drive after accepting I had lost all the content, but that does the same. I then ran the PC without any hard drive attached - the blue light obviously no longer flickers as there is no hard drive, but the ticking still persists. I've tried unplugging various elements within and starting up, but no change. i now think that the noise is actually coming from the switch, but that that is not what is wrong. Could it be a problem with the internal sealed power unit giving intermittent power? I have tried different cables also, no difference. please help, Thanks, Matt
  • Matt749 Nov 06, 2008
    Thanks guys, I'll give both of those ideas a go. There was a lot of dust and grime in there when I opened it up......
    Matt
    Problem Solver:
  • 6 Answers
Hi this is an odd problem. just keep the side off the computer start it up and listen in the side. you should be able to find where its coming from. if it is the power unit, i have never seen one yet that you cant open. sounds to me like the unit or cpu fan is clogged with dust n grime. you need to clean it out. let me know if this helps. you could also take everything out of the comp that doesnt have to be there, just leaving a cd-rom, floppy, hard drive and graphics card, then reboot......
Posted on Nov 03, 2008
    Problem Solver:
  • 8 Answers
It could be various components, try turning your system on and listening close to your system to hear where the sound is coming from, from that you can usually isolate the problem.
Obviously, if you do locate the component and replace it, make sure you keep the old parts and the receipt for the new parts, in case the replacement has no effect.
Worst case scenario, your motherboard may be fried. If this is the case, you'll possibly be looking at a new system - unless you don't mind replacing most of the components in there right now.
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Maytag washer mvwc400xw1 won't start
Hi Richard , sounds like you have something stuck in the pump . GOOD LUCK APPLIANCES R'EN
Jun 17, 2014 | Maytag MVWC400XW Washer
Loud ticking noise
Hi Anonymous, could have a lifter gone south and or broken valve spring, bent or stuck valve. Good luck
Apr 01, 2014 | 2002 Harley Davidson VRSCA V-Rod
2008 Highlander will not start. Makes a ticking noise when pressing keyless start
Immobiliser ?
Try this thread it may help - http://www.helpowl.com/a/Toyota/2008-Highlander/Research/5115?search=2008%20toyota%20highlander%20vsc%20check%20engine%20light
Mar 19, 2014 | 2005 Toyota Highlander
Ticking Noise 1990 Chevy Cheyenne pickup
use a timing light to check the degrees btdc
Should be 10-12 degrees btdc
could be injector click or hydraulic cam followers noise although I thing that would be audible on the coast action as well
check fuel pump as they click when working
May 27, 2017 | Cars & Trucks
Control lock light is on - The washer won't work. I unplugged overnight, and the light is still on when I plugged it in this morning. When I press Control On, HOld start, and Pause at the same time, the...
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle button. The control needs replacing if no stuck button is found and unlocking it is not possible. Please let us know if that is the case and if you need further help. Just indicate the exact model number of the machine.
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wharfdale DVDR24HD160F
Hi Barb22,
Sounds faulty to me, I'd take it back to the store and get a replacement. However, I guess you want that DVD out first? I'm not sure this will work because the units logic board is mostly likely faulty and will prevent the DVD transport from opening. Unplug the unit and press the eject button, keeping it pressed plug the unit back in. If the unit does not come on then press the power button too. If the unit starts to open release the button immediately. It's unlikely to eject, but you might get lucky.
Sorry I can't be of much further help.
Regards,
Spare head 2
Please don't forget to rate this response.
Jan 13, 2008 | Wharfedale DVD-M3 DVD Player
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Computers & Internet Logo
135 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
