Question about Microwave Ovens
Samsung M1774 850W Heard a snap like noise. The unit comes and everything appears normal but is not cooking. The the humming noise is missing, which I relate to the cooking part.
  • Microwave Ovens Master
  • 9,098 Answers
I would suspect that your high voltage rectifier diode may have shorted or blown open.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted and has no chips in it, it's probably fine)
You can order Samsung parts here.
Posted on Nov 09, 2008
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
Everything appears to be working with our microwave except it is not heating or cooking. All other functions appear to be o.k. I am not 100% sure of the model number and I'm not at my house to get that...
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("runs but no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
Nov 22, 2009 | Goldstar MV-1615 Microwave Oven
Our JVM1653 stopped cooking, everything else works
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
Oct 10, 2009 | GE JVM1653 Microwave Oven
Making a humming noise when turned on and not cooking. I punch in the cooking time I would like and then when it turns on it makes a humming noise and does not cook.
From your description it appears that the Magnetron has failed on your microwave.
*Please be aware*
Replacing the Magnetron in a Microwave is a highly specialist job and should not be carried out by an unqualified person. Microwaves carry lethal levels of voltage even after they have been unplugged from the mains supply. The high voltage circuitry in this area of the oven is extremely dangerous and must undergo a discharging process before work can commence. The Magnetron itself is the main 'engine' of the microwave and operates under extremely high voltages.
For this reason I strongly urge you not to attempt this repair yourself but have it carried out by an electronics repair shop. The cost of this is likely to be prohibitive and you will need to weigh up whether this repair is economically viable or whether you would be better to replace the unit altogether.
Hope this helps. Thanks for using FixYa.
Sep 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
