Question about Epson TM-H6000III Thermal Printer
INTERFACE QUESTION FOR C31C411A8460
WHAT INTERFACE DOES THE MODEL M147C COME WITH?
I NEED ONE WITH RS232 25 PIN. DO THEY HAVE A KIT TO CHANGE THE INTERFACES SINCE THESE PRINTERS HAVE MULTIPLE INTERFACES AVAILABLE, I BELIEVE.
  • Epson Master
  • 1,879 Answers
The Interface is interchangeable. Specify a SERIAL Interface when ordering the unit.
http://pos.epson.com/bizPart/bizPartDIS.htm for more info
Posted on Nov 03, 2008
Machine well not turn on it has f 70
NOTE: I do not recommend checking voltages unless you have experience and feel safe and confident in doing so, otherwise I recommend calling a service technician to diagnose and repair your washer.
QUICK TEST
  1. Lock the control by pressing and holding the cycle signal button.
  2. Press the Power button.
  3. If the lock light flashes when you press the power button it indicates the center interface was able to take the input and the Right hand User Interface received the DCV signal from the Center User Interface but since the display did not light. This indicates an issue with the Right hand user Interface.
NOTE: This is a quick test you can try to get to a quick resolution, but remember if the Lock Light does not blink once the power button is pressed you will need to follow the standard checks below.
  1. First try to put the washer into the Diagnostic Test Mode per the Tech Sheet by pressing any key except Stop/Cancel and the Control Lock for 2-5 seconds on and 2-5 seconds off 5 times as outlined on the tech sheet; at this point the Right Hand Interface should light up.
  2. IF the Right Hand Interface did not light up in Step 1 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). If you do not have the 5 VDC then replace the Machine Control Board.
  3. IF the Right Hand Interface did light up then remove the J003 connector. This is the 9 pin connector that goes between the Right Hand Interface and Center Interface.
  4. Short across (Pin 7 to Pin 8) on the Right Hand Interface.
  5. IF the Right Hand Interface did light up then replace the Center Interface due to a failed "Power" key.
  6. IF the Right Hand Interface did not light up then check from (Pin 1 to Pin 7) and (Pin 1 to Pin 8) on the right hand interface at the J003 connector you should have between 1.2vdc to 1.5vdc.
  7. Also check for DC voltage on the J004 (10 Pin connector) on the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 10. You should have between 1.5vdc to 5.5vdc.
  8. IF you do not have the DC voltage at either of the checks above replace the Right Hand Interface.
NOTE 1: The #1 Pin on both the J003 and the J004 is identified by the white wire. NOTE 2: The picture below is the J004 connector that goes from the Center Interface to the Right Hand Interface and the red arrows are pointing to the check points for the 4 to 5 VDC and the J003 connector.
Image 1 Image 2
Post back your findings and your model number.
Nov 02, 2012 | Kenmore Elite HE5t Washer
Teac diskette drive pinout for Technics kn1000
Sorry.
There was an interface included, inside the KN 1000 unit floppy disk drive. This interface change "the 34 pin out from the floppy disk)" to "the 24 pin out" that could be connect to the the KN 1000 "24 pin in" conector jack in the KN 1000 main board.
As we know, the common disk drive unit in the market have 34 pin out only. wa can't connect directly 34 pin out floppy disk drive to the 24 pin in jack connector inside the KN 100o main board.
We need such an interface. This is the problem coz no one sell this interface separately in the market.
If u have one KN 1000 floppy disk drive unit (SY-FD), u can pick out that interface from inside the unit, and use it as a gate/interface from your new floppy disk drive to the "24 pin in" connector inside KN 1000 main board.
U can search this 24 pin out diagram interface in the net, but the problem is no one sell it separately.
Jun 20, 2012 | Teac IBM USB Portable Diskette Floppy...
I've lost the installation disc and want to transfer mini dv films from my canon mv930 to my computer
According to page 80 of the user manual for this camera (click here for manual), the installation disk will not help you with transferring movies from your camera to your computer.
The instructions state that you will need a computer with a 4 or 6 pin DV (firewire) interface adapter, a 4 to 4 pin or 4 to 6 pin DV interface cable, and the movie software that came with your computer. According to the user manual, drivers for this DV interface are built-in to Windows 98 and later versions of Windows.
Assuming you have a Windows computer, I would suggest using Windows Movie Maker to import and edit your movies from your camera. If you have a Mac, then iMovie will be able to handle this very nicely.
The 4 to 4 DV interface cable is available here: (click here)
The 4 to 6 DV interface cable is available here: (click here)
Your computer will have to have a 4 or 6 pin firewire adapter either built-in to it or provided by an add-on card of some sort.
If you provide the make, model number, and operating system of your computer, I may be able to suggest some sources for the firewire adapter if available.
Thanks for using FixYa. If this solution was helpful, please choose either 3 or 4 thumbs-up to show that it helped you.
Mar 05, 2011 | Canon MV930 Mini DV Digital Camcorder
Teac external floppy disc drive will not format floppy disc
U need an interface, if u want to use the "34 pin out" from floppy disk unit, to the "24 pin in" connector jack, inside KN 1000 main board.
U can get this interface unit bboard from "the KN 1000 floppy disk drive unit".
Just open this unit SY-FD20, and pick out that interface board from this unit,
Then use it as interface to connect your new 34 pin out floppy disk drive to connecting to the 24 pin in connector jack inside the KN 1000 mainboard.
Feb 06, 2011 | Teac IBM USB Portable Diskette Floppy...
BUfFER OVERFLOW
The error you are getting "Buffer Overflow" is occuring due to flow control not working on the serial interface.
You need to check the serial interface settings on the pritner, ensure these match the host computer system (Protocol, Baud Rate, Paraty, etc)
Also check your serial cable, ensure the pin configuration is correct.
My guess is the printer is set to Ready/busy and you are running Xon/Xoff, you will need to change this in the printers menu along with the other serial interface settings
Oct 15, 2009 | TallyGenicom 6306 Matrix Printer
How to program a motorola gp328 vhf 2 way radio?
i have program kit and software i need program for emergency siren what i have to do
Jan 04, 2009 | Motorola Radio Communications
Transfer data
Hello tompkin,
Programming the Garmin Rhino 120 using a PC requires an interface kit and may also require a RS-232 to USB converter cable or a 9-pin to 25-pin serial adapter depending on what interface is available on your computer.
The interface kit and cables are available on the manufacturer’s homepage for the product: www.garmin.com/products/rino120. Click on the “Accessories” tab and scroll down.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 06, 2008 | Garmin Rino 120 2-Way Radio
Difference between ata and sata hard disks
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Feb 18, 2008 | Highpoint Technologies 1 Bay e.SATA...
Epson TM-H6000III Thermal Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
