Question about iRiver X20 MP3 Player
Rotary control the control button jumps across several icons/albums in menu mode. in play mode it turns the volume down when it should be increasing it. generally, the control button has become completely unpredictable.
  • ozeman Nov 04, 2008
    I too have this same problem only sometimes I don't even need to touch it and the volume decreases. It seems to be very touchy when scrolling thru the menus and can sometimes take a few attempts to scroll thru to get to the right selection.....very frustrating :(
  • k1andk Nov 15, 2008
    Thanks - but I didn't feel confident enough to open it up. Instead, I used a spray switch cleaner and that seems to have solved the problem
  • 49 Answers
Well, unfortunately the problem would be with the wheel itself or the circuitry.
if you cant find anything else and you're desperate, open up the casing and clean the wheel thouroughly...
Posted on Nov 06, 2008
I have a IPOD nano MC526LL that keeps playing the same song or podcast over and over. This is something new. can you help??
Sounds like you've accidentally touched the repeat button.
1. Play the song.
2. On the Now Playing screen, you will see play and volume controls (bottom of the screen).
Under the album title is a scrubbing bar that indicates the time remaining of the song.
3. A small icon that looks like two circular arrows is on the left side below the scrubbing bar.
Tap this icon once to repeat the album. The icon will turn blue when repeat is activated.
4. Tap the icon again to repeat the current track. The icon will change to show the number 1 inside a blue circle.
5. Tap the icon a third time to turn off repeat. The icon will turn white when it's deactivated.
Aug 12, 2014 | Apple Mc526ll/a Ipod Nano 16gb - Silver
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
How to turn on ringer on hydro xtrm kyocera cellphone
There are two ways. On the left edge of the phone, near the top, is the volume button. Turn up the volume by pressing the top of the rocker button, down lowers the volume.
You can also mute and unmute the phone from your home screen. Press and drag your finger from the upper left corner, down. This will bring up the "Notifications" menu. Across the top are 5 icons (Wi-Fi, GPS, Bluetooth, Sound, and Airplane mode). If the sound icon says "Sound on", you can press it and it will switch to "Vibrate", and then "Silent", and then back to "Sound On". Hope that helps!
May 02, 2014 | Kyocera Cell Phones
Keeps repeating
You can simply "set the repeat mode" to OFF:
1. Play the song.
2. Tap the now playing screen.
3. On the Now Playing screen, you will now see play and volume controls at the bottom of the screen. At the top is track information. Under the album title is a scrubbing bar that indicates the time remaining in the song.
4. A small icon that looks like two circular arrows is on the left side below the scrubbing bar. Tap this icon once to repeat the album. The icon will turn blue when repeat is activated.
5. Tap the icon again to repeat the current song. The icon will change to show the number 1 inside a blue circle.
6. Touch the icon a third time to cancel any repeat. The icon will turn white when it's deactivated.
Nov 22, 2013 | Audio Players & Recorders
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
I have lost the Instructions for my portable CD/MP3 player. I simply need to know what the various buttons do: Mode: 10+Album:Skip/Search: Play/Pause: Stop :Eq/Prog : Vol+-
mode: for repeat
10+Album: to change song more than 10 like 11 19
Skip/Search: press one time will go to next song press and hold search the song
Play/Pause: start playing song or make it stop
Stop : stop the song you are playing
Eq/Prog : setting menu
Vol+- increase or decrease the sound
Jul 29, 2011 | Audio Players & Recorders
Dont know how to control the volume, i cannot find my manual
Most of the time their are multiple ways to do this.
1. On the speaker in the lower right hand corner left click and a volume bar appears. Slide it up and down. It should be adjust to 75% IMO.
2. On your keys there should be symbols that look like speakers that should match the color of you "fn" key. Press and hold the fn key and then press the corresponding speaker key to increase or decrease the volume.
3. There may be a rotary volume control on the front of the laptop case. It's as simple as turning it to increase or decrease it.
On the volume bar in windows verify that the muted in unchecked.
Mar 10, 2011 | Computers & Internet
I cannot turn the volume down. i even removed the plastic button and turn the post but the volume will not go0 down
If it doesn't get louder when you increase the volume, then possibility that is not the volume control or the potentiometer isn't in volume adjustment mode. Try pushing the knob before you rotate it, it might switch to a different function. Other cause could be that the switch is smoked. This is possible specially with analog type rotary and slider potentiometers. With digital static switches it also happens when it's just so used up and doesn't conduct electricity at the contact surface inside the wafer casing.
Jun 19, 2010 | Car Audio & Video
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
iRiver X20 MP3 Player Logo
83 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
