Question about Amana Refrigerators
My amana ABD2233DEB bottom drawer freezer is producing lots of frost/ice on the food.
  • sbosse63 Nov 03, 2008
    can you help troubleshoot this problem?
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 3 Answers
    SOURCE: Kenmore elite bottom freezer. Frost, Ice tray
    The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
    Posted on Apr 02, 2009
    • 109 Answers
    SOURCE: Subzero freezer has frost/ice build up on the
    Check the fan and readjust temperature control to higher. Thanks.
    Posted on Oct 22, 2009
    • 3 Answers
    SOURCE: Frost is building up in bottom freezer. Amana ABB2224DEW
    I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
    Posted on Jun 05, 2010
    2002 amana bottom freezer full of frost took food out turned off freezer now what ? ice maker never installed !
    Is the thermostat set too high? Does it ever turn off?
    It could be the door seals, check to see if intact, if so, could need cleaning so they seat properly.
    Finally, should there be draw covers, which have been removed?
    Oct 01, 2012 | Amana ABB1927DE Bottom Freezer...
    Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
    Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
    If you need any further assistacne please feel free to comment me.
    Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
    My freezer is producing a lot of ice. There is buildup on the side racks, making it difficult to push/pull the top drawer. There is also frost/ice build up on the back of freezer and bottom floor. I...
    This always happens when you don't have 'FROST-FREE' refrigerator. Unplug the power cord or switch off the freezer for about one hour or more when lots of frost stacks (maybe weekly). Turn down the cold lavel to 2-3 instead of higher if there are not so many items in the freezer.
    Nov 12, 2010 | LG LFD22860 Bottom Freezer French Door...
    Bottom freezer drawer doesn't slide out easily, frost builds up
    3M spray silicone lubricant in 24 oz cans is good down to -23 degrees and FDA approved for being around food. Works a treat.
    Jun 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
    Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
    My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
    You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
    Contact an appliance service company.
    Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
    Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
    1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
    Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
    Apr 12, 2008 | Refrigerators
    Amana BX22A2W - freezer works, fridge not cooling
    Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
    Dec 02, 2007 | Refrigerators
    Refrigerators Logo
    65 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
