Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 665-16829000, #72 on control panel not going away
The number 72 is showing on the screen where the time usually shows.
Is this a problem code? I don't have the manual so can't look it up.
  • 1 more comment
  • steele165 Nov 04, 2008
    It always says 72 but it will start.
    IS
  • steele165 Nov 05, 2008
    The 72 went away for a minute but came back.
    Thanks for the help...where can I get a users manual?
    IS
    Sergeant:
    Champion:
  • 324 Answers
Does it always say 72? will it start? you could have a stuck key on the consol.
Posted on Nov 04, 2008
  • and it won't count down? sounds like a console problem.try pushing sanirinse-air dry-sani rinse-airdry and tell me what happens. do this with nothing on in the display.
  • you either have a bad control or console.
Most buttons dont seem to respond and the number 2 shows up and seems to be a countdown of 2 minutes. I can hear the motor running during that time. but it wont run, what is the prob?
Sounds like it is only going into the Cancel/Drain cycle. Probably a short in the control panel membrane. You will need to replace the control panel.
Nov 25, 2014 | Whirlpool Gold Series Quiet Partner Iv...
Kenmore dishwasher water stopped coming in
Check the valve under your sink. If that's on go to the dishwasher. Remove the bottom panel. Locate the water inlet valve (usually on the left hand side. Pull the two wires from it and put your voltmeter on it. Start the dishwasher and watch the meter. If it shows 120v then the valve is bad. if you don't get 120v, the board or timer is bad.
May 28, 2012 | Dishwashers
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
Upon plugging in the microwave, several beeps are heard and the touch screen displays "Touch Error". After a few seconds the error message goes away but the touch pad is not functional. The Kenmore model...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a full one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 08, 2010 | Kenmore 63792 Microwave Oven
Display shows F 7 ???
assuming that ur brand is a kenmore oven.....
I'm afraid F7 on that make of range usually indicates a problem in the control keypad in which case on your model the whole console panel usually needs to be replaced to correct the condition.
LINK > Kenmore 911.47469690 Control Panel, Black
LINK > Kenmore 911.47469690 Control Panel, White
LINK > Kenmore 911.47469690 Control Panel, Almond
have a nice day
thankyou for using Fixya
Jul 18, 2009 | Kenmore Ovens
Control panel showing count down number "999,888, 777, 666, ...."
You somehow got it in TEST/Maintenance mode. I think if you PRESS and HOLD Start for 15sec, it will go back to normal. If not, pull the plug and let sit for 1/2hr
Cheers!
Mar 26, 2009 | GE PDW9200N Built-in Dishwasher
Model#665.15829000 kenmore
sounds like you have a stuck key pad on the touch control board. there is no easy way to check this, but you can unplug the "ribbon" strip from the control board. then you will need to jumper the board to see if you can force the unit to run by bypassing the key pad.
i cant find an exact match for your model number, but if you check the wiring diagram, behind the lower access panel, it will show you which 2 terminals can turn on a cycle.
the best thing i can tell you is to just replace the control panel with a touch pad assembly. it could cost about 125-150 bucks, but that should fix the problem.
Jan 30, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
I have a Kenmore Elite, model number 665.17263. The clean button green light is flashing. This happened once before and it was the heating element. The service guy showed me how to put a series of presses...
Push the Heated Dry then the SaniWash buttons. Do this three repeatedly until the whole panel lights up and then close the door. You should be good to go!
Dec 03, 2008 | Dishwashers
Kenmore elite model165.15989990
Replace the control electric first.If you have visual crack/cracks in touch pad then you have to replace it also.
Apr 01, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
193 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
