My C-Drive is full so how can I shift stuff to my D-Drive? Thanks
    Scholar:
  • 32 Answers
I would assume that the D Drive is a secondary Hard Drive for Storage. If that be the case. Here are 2 ways to move your Data .
1. Go into my Computer and double click on the C drive. Once this is showing all your files. Leave this open and Go into My Computer again and this time open up the D Drive. Now you should have 2 windows open. If you wish you can resize the windows so they are next to each other and you can work with them. Here we can Drag n Drop the folders or files from the C Drive to the D Drive. To Do This you can left click on a file or folder on the c drive and once you click it hold the mouse button down when you click and then just drag it over to the D Drive Window. And let go. This will move the folder or file from one drive to the other. You can also select multiple files or folders by holding down the control key when you click. You select one then the next one and so on, they will remain highlighted showing you they are selected, then you can drag them all over to the D drive Window.
2. Another way is to select the folder or file you want to copy, And right click on it. A pop up menu will appear. Scroll down to copy and left click.... Now you can go to the D Drive window and right click in there and select paste. This will copy the folder or files into that Drive.
Hope this is clear to understand...
Joe < Data Miner >
Posted on Nov 03, 2008
I have a 1999 dodge ram 4x4 1500 it seems like it is slow at take off and sometimes it doesnt want to shift right out of first can you help
check your ****** fluid. if it's full at normal operating temp. you can try adding Lucas transmission fix. it costs like $12 at wal-mart. it helped my ram out alot. but make sure you have your truck at normal operating temp while checking the fluid. i had mine idle while i put it in. it is thick so i will have to cut the nipple and squeeze it into the dipstick tube slowly. after u put the entire bottle in, drive slowly and shift from low gear slowly up to drive, then in neutral for a sec, then stop and go into reverse for a a few seconds. that way the fluid will get to all the bands and recondition them and it helps lubricate the gears better. Lucas makes some very good stuff. i use all their products with faith. the stuff works that is if you bands aren't already shot. it also is supposed to eliminate leaks. hope this helps.
Jun 10, 2011 | 1999 Dodge Ram
Just bought 1999 forester, transmission sems to have two second delay when shifted into drive is this normal ? no delay when shifted into reversre. thanks
The Forester is a great vehicle, and No, it's not normal to have a 2 second delay when shifting into drive.
This is what I would do, and in the order that I would do it in;
1. Make sure your transmission fluid level is full. If it is;
2. Change the fluid and filter screen in the transmission. Your issue is small right now and the sooner you get it resolved the less likely it will become a major problem. Also, when we buy a used vehicle it can be difficult to know if it has had regular maintenance done it. If you still have the same problem;
3. Have the shift solenoid/shift motor on the transmission checked.
I hope this is helpful.
Feb 10, 2011 | Subaru Forester Cars & Trucks
1975 chevy blazer with a hydro-matic 350 automatic
check your kick down cable attached to the carb, it may be out of adjustment and forcing the trans to stay in "passing gear"
May 28, 2010 | Chevrolet Blazer Cars & Trucks
My van slides when you put it on drive and when this happenens the service engine soon light was coming on. my question is do I need to replace the trnsmission or could it be a sensor because when it's on...
Your best, and least expensive, way to possibly rectify this problem is to have the fluid and filter changed in the transmission. If you have already tried this then you need to have a professional tranny shop diagnose your situation. Thanks Dana. P.S. You might want to try a bottle of Lucas transmission treatment, this stuff has been known to do miracles. And I don't usually suggest any mechanic in a can, but, this stuff really is incredible. Thanks, Dana
Mar 30, 2010 | 1999 Chevrolet Venture
Reset to factory dettings
Hi
I am not sure on which drive the OS is installed. You can confirm if you can see Document and Settings folder on C drive. It means you can do all operations on D drive. To make it clear you need not to reset you just Select the Files and Folders which dont need it and press Shift+Delete. it will ask your confirmation before deleting the stuff. If sure press yes for all.
It will remove all the selected stuff from the D drive.
I recommend this becuase I am not sure whether you have Recovery disc provided by show owner.
Sep 18, 2009 | E-Machines eMachines Desktop PC
My acer aspire one hangs when i set to standby mode
You don't specify but it seems like you are using Windows. This problem can be caused because you didn't set up an Account name. You can add one user, give yourself full admin rights, and do NOT require a password.
Default in Windows from standby is to log in as user...it goes wonky if no user is set. It can't find the user and does not know what to do, you have to reboot to get out of it, all stuff saved is lost.
BTW When you are at the Standby screen, hold down SHIFT key and it will change to Hibernate, if that option is available. Hibernate saves all your stuff to the hard drive and powers down..much better for batteries than Standby
Hope this helps
Jun 12, 2009 | Acer Aspire One PC Notebook
One drive is small and full... how do i combine it with the other
you can use a program like Acronis to make an image of the 18 GB drive and copy it to the 280 gb drive, then just remove the 18 GB drive.
You can download acronis from www.download.com
Jan 17, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
My d drive is full
Hello caliandrew88,
Having a full D Drive will not cause Vista to crash. If you need to free up space then get an external hard drive to move files off of your machine.
- Vincent
Nov 22, 2008 | Dell Dimension E520 PC Desktop
1080p Prob with TH-50PE700U
try diffrent hdmi cable, sometimes with this new digital stuff there are compatibility issues, not common, but not unheard of
Feb 20, 2008 | Panasonic (TH-50PZ700U) Television
Low space
Have you tried clearing the "Temp" and the "Prefetch" folders?
Go to Start -> Run
Type - "temp" (without the quotes) in the run dialog and delete all files with Shift+Delete.
Repeat the same operation with the prefetch folder. (Type prefetch instead of temp now)
It should be able to clear just a few MBs.
Also, I would recommend uninstalling any unwanted software that you may have installed on your system.
Also, as it is evident from your above post, you have been saving a lot of stuff in the My Documents folder. I would hereby recommend saving large files on the C Drive(D) drive so a balance would be maintained.
Oct 17, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
