Question about Garmin GPSMAP 76S GPS Receiver
Screen goes blank except for a verticle streak
I have tried new batteries even. After it aquires, the screen goes blank except for a verticle streak. The streak is not always in the same location.
  • Anonymous Nov 17, 2008
    same problem
  • dlkaisler Nov 27, 2008
    same problem
    Problem Solver:
  • 7 Answers
I had the same problem (blank screen, vertical line). After speaking with Garmin, I was told to make sure I was using the latest software version, and to turn off the WAAS function. Disable it for now, because the WAAS signal, coming from the satellite, has changed, and Garmin has not yet published a remedy to correct this problem. A fix should be out in a software update, sometime in the future, hopefully. I also did the software update, to the latest version 4.0. The unit performs perfectly now, however, the accuracy is not quite as good, due to the lack of WAAS. Good Luck!!
Posted on Dec 14, 2008
Verticle lines/streaks down screen
The Display panel could be bad/damaged or the main board that controls every thing could be bad---parts for Dell equipment are known to be hard and sometimes impossible to find.
Dec 07, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Blank screen
If you can play back captured images without any problem then your camera has a faulty CCD sensor. If you can get hold of a new CCD sensor block for this model somehow then you can install it yourself. Otherwise camera has to go to your Nikon agent.
Sep 14, 2007 | Nikon COOLPIX P4 Digital Camera
5yr old Garmin 76s shuts off
KUDOS! Others with the same problem informed me that it is a softwear problem and to download the 4.0 version free on the Garmin web site....l'll do it ASAP and write again if it doesn't work...RG
Jul 19, 2009 | Garmin GPSMAP 76 GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Screen goes blank before i can key in pin number
have the flexcable replaced and try also a new battery
Dec 27, 2008 | Motorola Mobility RAZR V3
HTC p3300 often hangs up(black screen, no response to any buttons) when programms with high mem. are running e.g media player
try getting a new battery
charge it while its off!
when the charge LED goes off its done..
Nov 10, 2008 | HTC P3300 Smartphone
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Screen goes blank when capture button is pushed
Seems to be a problem with the camera and the batteries. It thinks the batteries are dead but they aren't, this is the problem I am having with my camera, I'm going to try new batteries and see if there is a Firmware upgrade.
Dec 24, 2006 | Fuji FinePix E510 Digital Camera
Garmin GPSMAP 76S GPS Receiver Logo
169 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
