Question about Garden
Homelite broom help I put way too much oil in now it's smoking!
I put oil directly in the tank of the blower instead of mixing it with one gallon of gas! I put the same amt of oil for one gallon directly in the small tank. It started then smelled and smoked a bit, then stopped. What do I do now? Can I drain and start again with the correct ratio? Help! It's been over 3 years since I used it and it would have been NICE if the ratio had been printed on the darn thing.
  • stineaac Nov 08, 2008
    Thanks! I'll do that. I'm not sure where the plug is or how to change that though. Thanks again!
  • Anonymous Mar 16, 2014
    how much high performance 2-cycle oil do i mix in a 2.7 gallon gas tank?
I agree finding the ratio is no as easy as it should be. yes. drain the tank. don't use the old gas somewhere else. use fresh gas & mix ratio in separate gas can or container. use a bit of ether/starting fluid into the air-filter inlet opening help fire it up. a new plug is fairly low cost and easy and that might also be needed after the oil bath and 3 years.
Posted on Nov 08, 2008
UT10625C: fuel mixture ratio?
First 2-cycle additive motor oil stays fresh for about 12 months. If other than Homelite oil is used it is suggested that a mix of 16:1, which is 1 gallon of gas to 8 oz. of the mix.I got this information out of my homelite manual. The best rule of thumb is that you want the chainsaw to smoke alittle while running. That way you are sure that the motor is being lubed.
Apr 01, 2015 | Homelite Garden
Are all homelite yard brooms gas n oil mix?
All teh ones i ever seen were two cycle engines which takes mixed gas........Hope this helps.
May 20, 2011 | Homelite 'Yard Broom' Leaf Blower
How much oil do you use? in the mighty lite
Homelite Mighty Lite engines require the gas/oil ratio to be mixed at 50:1. That is 2.6 ounces of oil per gallon or 1.3 ounces of 2 stroke oil per half gallon of gas. I recommend using synthetic oil. It lubricates much better, allows the engine to run cooler and smokes less.
Apr 05, 2011 | Homelite Mighty Lite Blowervac
I have a Homelite YARD BROOM II 170 mph Blower.what is the oil to gas ratio?
I usually mix at 50:1 useing klotz two stroke oil,or 44:1,klotz is high performance zynthetic oil,also has nice sweet smell when running,keeps the neighbors from complaints on bad smell.
Feb 11, 2011 | Homelite 'Yard Broom' Leaf Blower
What is the fuel gas ratio for a homelite yard broom ll 170mph blower
The mixture should be at a 50:1 ratio, using Premium Exact Mix™ 2-cycle engine oil. If Premium Exact Mix™ 2-cycle engine oil is not available, use a high quality 2-cycle engine oil, mixed at a 50:1 ratio.
You can get the manual on the link below if you need it also.
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Homelite 'Yard Broom' Leaf Blower
What is gas/oil for yard broom?
what you have to do is get two cycle oil and follow intructions from container for mixture and after you mix put the mixture in your blower.
Nov 15, 2009 | Homelite 'Yard Broom' Leaf Blower
My redmax eb7001 emits white smoke while running, the more power...the more smoke
Your fuel-oil mixture has too much oil in it. The standard ratio is 40:1 which means one of the little bottles of 2-stroke oil (about 2.6 fluid ounces) is added to 1 gallon of gas. Homelite recommends a 50:1 ratio but 40:1 is better, at least in my opinion.
The last time you made the mix, did you pour the oil into the gas or did you pour the oil into a little bit of gas in the gas can, shake well and then fill it with a gallon of gas? The former can give you lots of smoke as well because it is not mixed thoroughly. The latter is the best way to mix because the agitation and the flow of gas mixes the oil better.
Other possible causes to this problem are: how old is the mix you are using? Did this mix sit all winter last and you sre using it now? If so, did you add some Stabil to the mix before storing?
Depending on your answers to the above questions, you can determine why you are getting so much white smoke.
My recommendation to you is to:
(a) Empty the blower gas tank.
(b) Mix a fresh batch of oil and gas in an approved fuel container.
(c) Pull the spark plug and inspect it, if it is black/sooty replace it.
(d) Pour the new mix into the tank and start the blower.
This should get rid of the excess smoke, if it doesn't, let me know here. Good Luck!
Oct 22, 2009 | Homelite 'Yard Broom' Leaf Blower
Is it a gas oil mix?
Yes, most likely. I am not sure what model you have, but if you don't put oil in the crankcase, then it is. I would mix 50:1 ratio. Use optimix. one tube for a gallon of gas. It burns clean and they warranty any motor you use it in. When you use this, it doesn't matter the ratio, so you can use it in all of your 2 stroke units. Also, it won't hurt a four stroke unit either.
Jul 05, 2009 | Homelite 'Yard Broom' Leaf Blower
My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
What is the proper gas/oil mix ?
If you dont have your owners manual, than id try 40:1 mix. If it smokes alot than cut it back to 32:1
Dec 22, 2008 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
284 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
