Question about Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG9341 (purchased 9/10/08)
How to get my handset phone working again. Last night it was working, but today "check tel line" is shown  on the handset display. I have followed the directions in the Quick Guide for Quick troubleshooting, but have had no results. I have also called ATT and they will send a repair man to check the lines tomorrow.  Could there be something wrong with this new phone. What other troubleshooting options do I have?
  • bennel62 Nov 26, 2008
    Digital display shows the message: "Check tel line", but when we plug in another (different) phone, it works just fine.
  • Anonymous Mar 26, 2014
    New phone is charged but msg says check tel line. What is this?
When i use speaker phone the system shuts off and indicates: "no link to base"
John C.
Posted on Jun 23, 2012
Hi folks,
The problem was the telephone line after all. The ATT repair men fixed it. It was not the phone at all. Thanks.          Yatchan
Posted on Nov 05, 2008
I believe the problem is not the handset phone but the telephone line because the phones were working for a brief period again last night. As I said, ATT is supposed to send a repair man out today to check the lines. If the repair man says the problem is not the telephone line, I may contact you again. Thanks/
Posted on Nov 04, 2008
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
Panasonic KX-TG6711E Cordless phone
Have you check another phone jack in the home? sometimes it is a bad jack that cause it not to work
May 13, 2014 | Panasonic KX-TG4500 Phone
Landline displays screen message Check Tel Line. Can't phone out or receive calls. Lights on the black box are out. I checked outlets, etc. E mail is weiner_@live.ca, land line 250-590-5196. Thank
I had to reboot our Shaw box three times last night before the phone started working again. Not sure what triggered the "check tel line" in the first place. My husband had just finished a phone call, I was going to make one right after him. The msg appeared as soon as he hung up. Interesting about your having a Uniden phone; it's the same brand as ours. This is the second time in a year that we've run into this problem. As for your old phone, is it analog? Reason I ask is, our rotary analog phone will work when the digital one doesn't.
Jan 05, 2013 | Lands Phones
I have a Panasonic KX-TG2730 cordless phone set. It is a single line phone. We had to unplug it recently and get new batteries for the phone. When we put the batteries in they worked on the phone but when...
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 17, 2011 | Panasonic KX-TG2730 Multi-Handset cordless...
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
Phones stop working
What system is this on?
Aug 04, 2009 | Panasonic Lands Phones
Panasonic KX-TG1033S Cordless Phone Logo
847 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
