Question about Sony Cyber-shot DSC-N2 Digital Camera
Sony DSC T300. Problems with the flash
When I use the camera in mode "auto" or "PGM", I can't take pictures with flash.When I touch the button "flash" that appears on the right side, It only gives me the option "flash off" . How can I tourn on the flash?
  • 1 more comment
  • seansdad Dec 18, 2008
    I used to be able to see flash options in the pgm mode, but no more.
  • gzzrodrigo Mar 09, 2009
    Same problem for me
  • gigabytes Apr 18, 2009
    I have exactly the same problem but with the sony cybershot dsc-t300
    Could someone help me please?
    Thank you
Hello!
I just solved this problem: to put flash, while you are in shooting mode, touch MENU, then REC Mode on the first page, and touch Normal, to take a single picture and then OK, you'll have the Auto Flash which appeares; but I never knew how to put the other kinds of flash...
Posted on Apr 18, 2009
    to put all the kinds of flash, you just need to put your digital camera in the PGM Mode on the left, 3rd row.
I have a sony DSC T300 that the back touch screen doesn't display any video. It lights up and I makes the noise when I touch where the scroll arrows are (when in play mode) or where menus should be (in...
Hi your unit has lens unit defectiveness. It won't reset itself initializing. The noise come from initializing IS unit defect. your local repair shop would charge around $45 to 115 depend on what they really want to charge. thanks and best regard!
May 25, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
Flash is not working
Hi there make your camera in auto flash mode & take a snap in dark place. If the flash not work then you need to replace the flash tube. Thanks.
Jan 15, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
How do I operate the self timer on SOny DSC-T300? thank you
Touch the self-timer button (the one-handed clock) on the touch panel to cycle through the self-timer modes. Start the timer by pressing the shutter release button.
Nov 06, 2010 | Sony Cyber-shot DSC-T300 Digital Camera
I have a Sony Cyber shot T300 and th flash says its off and I cant turn it on.
go to the menu select flash option,fill the flash and then exposure mode scn/wrong light mode then try,if u get flash,if not problem with the flash unit as well as conectives
Mar 03, 2010 | Sony Cyber-shot DSC-T300 Digital Camera
Sony Cyber-shot T300 can't get the flash to turn on
Go to Menu =>Record Mode and select take a Single picture, it worked for me
Jan 01, 2010 | Sony Cyber-shot DSC-T300 Digital Camera
I bought a Sony DSC t700 approximately 6 months
If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
To set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness, press the UP ARROW on the control button until a lightning bolt icon appears on the LCD screen.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies
When set to the Twilight mode
If an external flash is connected
If in the Burst or Multi Burst mode
Please touch the MENU option on the screen of the Camera.
Then, select the REC MODE under the MENU.
Then, select NORMAL under the REC MODE.
If you're not able to select the NORMAL under the REC MODE, try Initializing the Camera.
First, please touch the HOME on the LCD screen of the Camera.
Then, select the SETTINGS in the HOME menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize under the MAIN SETTINGS.
If the issue still persists after performing the troubleshooting steps provided above service of the Camera is required.
It's required to physically examine the Camera to determine the exact issue at the service center.
Jun 16, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
My sony cyber super steadyshot model DSC-T70 flash does not work. Nosmile icon appears on the touch panel when shutter buton is pressed.
go into setup menu and turn on the smile detection. go to photo and press the right arrow should have a pict of flash icon . press until the flash says auto.
Jun 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
I turn off the flash on my sony dsc - t77 , how to turn it on? i could not find the function!
That solution does not work on the T77.
I have the same problem and this is how I solved it.
Press the Menu button on the bottom left corner of the screen.
Go to the second page (2/3) select the "REC MODE" (it is the firrst choice)
Select your mode as normal and not burst and then exit the menu.
Now you should be able to activate the flash from the screen..
Hope it works for you as it did for me.
Dec 27, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
111 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
