Question about Honda Electrical Supplies
Ihave a honda ganerater MODEL#ES3500 and dont know were the battery goes.
I have a HONDA generater MODEL #ES3500 and dont know were the battery hooks up.
The battery '+' attaches directly to the starter and the '-' cable is grounded to the frame/block.
Posted on Dec 11, 2008
  • bkmatth_62 Dec 11, 2008
    I am working on an ES 3500 right now. No power to the fuel shut off switch.
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Apr 10, 2015 | Honda EU6500isA - 5500 Watt Electric Start...
WHERE CAN i GET THE SPRING FOR THE PULL START ON ETQ 3000 GENERATOR
Never heard of an etq Honda generator,if is a Honda generator any Honda dealer should be able to help you. If its a Honda knock off ,some Honda springs will work.
May 30, 2014 | Honda 3000 Watt Portable Generator
What is a good generator to buy honda or yamaha for campers
I know not everyone has the same results with different equipment but in my experience I would recommend the honda .Ihave had both and the only reasons I ever did anything other than use it was when I bought a new one because I neede more power.The one yamaha that I had was hard to start from new and the few times I needed tech. help I was not happy with the response I got from yamaha. I hope this is some help to you. Thank you
Jun 06, 2011 | Reliance 30 Amp RV Parallel Kit for Honda...
I have a1990 honda xr80 dirt bike its 3 hose on the carburetor none of them are hooked up i dont no where they go could you help me hook them up the right way
Line from gas tank goes to brass nipple, throttle line goes to top threaded opening, the hole with two bolts alongside it go into the crsnkcase. air line from airbox clamps to the last opening on the carb. The of the openings are vents and overflow.
Oct 07, 2010 | RTO Honda Crf450 R Motorcycle Dirt Bike...
Where is battery located on honda es 4500
The battery for the ES4500 was not located on the frame of the generator. It had to be added with the battery kit which had a plate and cables that allowed you to connect a 12 volt battery.
Page 8 of the owners manual shows you how to hook up the battery.
http://ubermanuals.com/product/honda-es4500-13340
Oct 01, 2010 | Honda Electrical Supplies
Honda 7000w generator outputs 6vAc when idling. When I rev it, power is then supplied. Why?
Well I dont know, but I do know that when it idles nothing is going to work. So whats the use of having a generator idle? Generators must turn at 1800 or 3600 rpm to operate.
Mar 13, 2010 | Honda Electrical Supplies
CONTACT BREAKER GAP FOR HONDA ES3500 GENERATOR SPARK PLUG GAP.
Recommended spark plug is BPR5ES (NGK) W16EPR-U(Denso)
Spark plug gap is 0.7-0.8mm (.028-.031in.)
Air Gap for your ignition coil is .4+-,02 mm(0.016+-0.008in.)
Nov 16, 2009 | Electrical Supplies
220 volt outlet
you can find it in electrical store.
Jul 05, 2009 | Electrical Supplies
I need a carb for a es3500 honda
Good place for honda parts is http://www.jackssmallengines.com/index.html. I would try to repair the carb first using a kit containing gaskets and needle. enjoy
Nov 27, 2008 | Electrical Supplies
Electrical Supplies Logo
1,090 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
