Question about Acer AL1721 17" Flat Panel LCD Monitor
Acer al711 lcd
I have an Acer AL711 LCD monitor with a problem. It has no contrast but the OSD has contrast. I tried to change it from the monitor menu and it did not work. When I tried to change the color temperature from user to 9300 the monitor goes black, this also happens when I tried 6500, 7500. When I use the recall or auto adjust function the monitors contrast works for the time it needs to auto adjust and then it stops working again. I tried to: change the signal cable, used DVI signal, removed the connectors from inside the monitor to se if it?s a contact problem, used different refresh and resolution. Everything was ok. Is the changing of the monitors control board cheap? Anyone has any suggestions on what to do? Thank you, Cornel
4 Suggested Answers
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
budmrtn
  • 11361 Answers
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 31, 2011
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
How do you change the contrasting on the acer monitor x193W
Check for hidden buttons around the ridge and on the back if none are found you will need the software from acer to manage the display settings
Jul 21, 2010 | Acer X193W LCD Monitor
Acer AL175 TFT monitor is coming on but its very dim
The screen itself is starting to go bad which is why your having to turn up the brightness to 100% just to see something. Replacing the screen would cost more then the whole lcd monitor itself so its best to get a new one.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
Greeen filter?
?? the colour of the OSD is OK but the rendering of your video signal from the 'pooter is wacky? Either the video cable or video drive from the 'pooter is the cause.
May 01, 2009 | Acer AL1912 19" LCD Monitor
How to adjust intensity of Acer X193W LCD monitor manually
if you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Mar 06, 2009 | Acer X193W LCD Monitor
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
OSD Lockout
Have you opened the monitor's onboard menu and checked the OSD settings? Do that and see if you can change those settings there. I would also open the Device Manager and check for problems. If you see any yellow question marks, that hardware has a problem.
Sep 12, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Snowy Raster on display
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Jan 27, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1721 17" Flat Panel LCD Monitor Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
