Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water keeps filling and will not shut off, with any load size setting, We shut the water off manually, to keep from over filling
  • 5,911 Answers
Read through the following link for advice on what to do for an overfill problem:
http://www.fixya.com/support/r762094-washer_overflows
It is common to find the air hose to the pressure switch disconnected, causing this problem. What appears to be a serious problem, may just be a simple hose reattachment. Double check the electrical connections to the pressure switch as well. Make sure they aren't corroded, or loose. Read through the link I provided and let me know if you have questions. If you perform all the preliminary checks and still have the same problem, replace your pressure switch. I hope this helps you.
Posted on Nov 04, 2008
    Sergeant:
    Champion:
  • 324 Answers
Fill valve sounds bad.are you on well water?
part # 285805
Washer just keeps filling and never advances on large and medium loads only
Your drain hose is pushed too far down into the drain so when you select the larger load sizes the water is being siphoned out as it goes in due to the pressure differential.
Jun 01, 2012 | Electrolux Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
What controls the water cut-off feed during cycles and when dail is set in off position.
There are electronically turned on and shut off water valves that are controlled by a water level sensor which varies based on what load size/water level you need Small, Medium, or Large. So if the valve gets stuck open since it's an old machine, the water will just keep coming in. But let me ask you this? If you turn the house water value on n NOW...will the wash machine just start filling? If so, it means your valve is stuck open so you would need to replace the water valve which is like $50 online. If the house water valve is on, and when you start the washing machine it starts filling, but just keeps on filling...that's probably because your water level sensor is messed up. So you have 2 things to check...is it the washer water valve is stuck open? or is it the water level sensor that isn't sensing when the washer is full so it just keeps filling it.
Dec 21, 2017 | Home
My washer keeps filling with water. It wont stop filling on small med. Or larg. It just keeps filling.
If the machine keeps filling even when it is off the water valve is defective. If it stops when you shut it off then, You may have a damaged or disconnected pressure hose. This is a clear rubber hose that runs from the side of the wash tub up to the load size switch. Inspect the hose as best you can.
If the hose is in good condition and is connected at both ends then you have a defective pressure switch.
Jun 11, 2010 | Washing Machines
Water wont stop filling.
I have similar problem. Looks like the 2nd possibility. but how to open the front panel to check the small pipe that goes to the water level switch, as I notice there is not water going up there.
Thanks.
Sep 20, 2009 | GE WWSE5200B Top Load Washer
My washer keeps filling no matter the size I have
This sounds like a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water and signals the timer to start appropriate cycle. Make sure there is no damage to or obstructions in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
May 12, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Westinghouse washer lT609s - tap problem
if I understand you correctly ... your washer keeps filling with water and you must shut them off at the wall to stop the water from coming into it?
this is a stuck water valve .. there may be something in your water valve keeping it open...
unhook your hoses and check them..
hope this helps
Apr 05, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
