Question about Brother MFC-5460CN All-In-One InkJet Printer
Magenta clogged the magenta is clogged on my brother mfc-5460cn. it won't unclog by self cleaning. any suggestions?
  • 1 more comment
  • Anonymous Jan 06, 2009
    I have the same problem but with the cyan color
  • alpha642 Mar 06, 2009
    My magenta is clogged too. Same printer.
  • chrisep May 04, 2009
    I had the same
    problem with all the colors. After
    taking out the cartridges I used a straight pin to clean out the male
    tube where the ink goes from the cartridge to the machine. Then
    I used a q-tip or 2 to clean the sensors for each color. It has worked ok
    for a while now.
OK: Lets give you a hand and an advice, if you dont mind:
the advice:
brother uses DYE-ink for C/Y/M which contains an amount of glycerol and some cleaning fluids:
I guess you run 100ml ink boxes (so you might do a math operation ;-) for your amount needed)
Use 25 ml of glycerol (85%- glycerin alc from drugstore) and mix it with 75ml of dye ink very well.
Use 5ml glcerol and 95ml of ink for BK. This has to be shaken very well, because BK ink contains of diffrent chemiclas than Y/M/C.
Now the hand:
Make sure the CIS is placed well in place at printer side (and some how secured).
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will turn to maintenance mode (light will flash).
press 7 -6 -4 and then start bk-copy.
Machine will initialize the "carts", refresh ink in tubes and ph and delete all air which might be within the ink system (this could be the reason why you cant print mag!). It runs an extra power cleaning, too.
When finished, press 7 -6 -3 then start bk copy to do a power purge.
When finished press 9 then 9 to leave the maintenance mode. machine comes up in normal state.
Do run a test print and check all squares.
If you cant see any mag the ph is definitly clogged and needs replacemnet (brother ph techniques cant be cleaned by fluids or outside the system! So dont waist your money on cleaning carts which wont work!)
Posted on Apr 04, 2009
Machine says that magenta is empty, cartridge level reads empty. But when I put a new magenta cartridge in it reads no cartridge open cover and reinstall magenta cartridge. The cartridge is full and is a...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Sep 28, 2009 | Brother MFC-5460CN All-In-One InkJet...
When printing all the reds are coming out green and the orange color is coming out lemon yellow.
Magenta ink is not flowing. Go to your printer utilities (Control Panel>Printer and Faxes>your printer>Advanced and look for an option to clean the print heads. Or, replace the cartridge. If you haven't used the printer for a while (a few weeks maybe) ink can get clogged. Sometimes a bit of isopropyl alcohol where the opening is in the cartridge is enough to restore flow. Just a drop would be all you need.
Jun 25, 2009 | Brother MFC-5460CN InkJet Printer
Red ink nozzle on a brother mfc-240c is clogged
I found an article on how to unclog Brother inkjet nozzles on the InkMagic website. It worked for me.
http://www.inkmagic.com/Articles/Unclog%20nozzles%20on%20your%20Brother%20multifunction%20inkjet%20printer.htm
I'm also using their ink now. I'm a photographer so colour is really important to me. InkMagic ink is as close to the orginal Brother ink as I've found. The MFC-240 cartridges are here:
http://www.inkmagic.com/shopping/shopdisplayproducts.asp?id=1133&cat=Brother+MFC+240c
Hope this helps ... Dale
Apr 01, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Nov 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
Mfc 665-cw magenta clogged?
Do you use some very cheap generik ink?
If your ink wont match the specifications of the needed one clogging is the result.
If you have tried several cleaning there is unfurtunately nothing more what you can do: the ph is dead (for mag).
Mar 28, 2008 | Brother MultiFunction Center MFC-440CN...
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
My printer doesint print magenta on test page
Did you use third party ink? Insert a genuine (original) brother ink cart and do the cleaning twice. there should be magenta again. If there is no magenta after that, this could be either because of air in the system (thats why you should do the cleaning twice!) or the nozzels are clogged (and cant be cleaned anymore).
Sep 11, 2007 | Brother MFC-620CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
678 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
