Open lexmark printer x5070 to install ink cartridge
  • 3 Answers
To whom it may concern, I owe a lexmark x5070 and all of the sudden it doesn't work it doesn't come on nor has any signs of power can you tell me what has posibly wrong with it. thank you for your earliest response to thi message.
Posted on Dec 14, 2009
Right Cartridge is incorrect. But we never print in color.
Lexmark Printer Problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/13953
My printer Z12 Color Jetprinter is printing triple letters (printing on top of each other). ..... I have a Lexmark All-In-One X5150---It says "color cartridge missing" butthe ... We removed the ink cartridge and looked on the back of it and realised that .....to the right side of the computer ..if someone can tell me whats wrong or how ...
Lexmark Reset ink cartridge ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/35235
Jun 3, 2009 - Does any one know how I can reset my ink levels in the Lexmark All inone ... The best way to reset any lexmark inkjet is to buy a real printer. ... fool the empty ink cartridge signal on the Lexmark but putting a piece of "that never ..... So sure the printer prints but is it just using up the color cartridge to make the ...
[PDF]5000 Series User's Guide - Lexmark
Jan 18, 2016 | Lexmark X5070 ALL-IN-ONE InkJet Printer
I installed new ink and printer shows clear paper jam does not appear to have paper jam
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Oct 22, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
How do i reset me lexmark 5070 printer after i used a refill for ink
  • Launch "Printer Solution Center." You should have installed this program when you installed your Lexmark printer. Click on the Start button and selecting "All Programs." The menu command or shortcut for this program is located under the "Lexmark" folder. Click on it. If you do not see this program for some reason, insert the installation CD (provided in the printer box) into the CD/DVD-ROM drive. Follow the on-screen prompts to install the program.
    Step 2
    Click on the tab that says "Maintenance" on the top menu.
    Step 3
    Click on the button titled "Install a new printer cartridge."
    Step 4
    Hit "Next" to launch "Print the Alignment page" window.
    Step 5
    Hit the "Print" button. This will reset your ink cartridges. You should be able to see a correct reading of the ink levels on your Lexmark printer.
    Step 6
    Repeat this process until you successfully reset the ink cartridges. Sometimes, it may require multiple attempts to complete this task
    if you want to know how to reset the complete thing then...
    Resetting a Lexmark printer
    You will firstly need to switch off your printer. Then simultaneously press the RETURN and READY keys while switching the printer on. This will take you to the Diagnostics Mode. The display unit will show the message 'Performing self test'. Choose 'Maintenance count'. Reset the count to make it zero. Then select the RETURN key and go back Diagnostics Mode. Then you can reset the printer to go back to the normal mode.
    hope this works for you...
  • Aug 07, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    How to change cartridges for the lexmark X5070?
    Perhaps the Lexmark X5070 User's Guide will be able to help you. Just click on this link to download: http://bit.ly/cYIIHy. Scroll to Maintaining the printer for the instructions on how to install/replace the cartridges.
    In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source. Hope this helps. Thanks.
    Jul 24, 2010 | Lexmark X2470 All-In-One InkJet Printer
    I have to install the lexmark printer X5070 but don't have the cd to do so.
    Download them from here
    http://drivers.softpedia.com/get/PRINTER/LEXMARK/Lexmark-X5070-Printer-Driver-1023.shtml
    Mar 17, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    I just installed a Lexmark X5070 which was given to me second hand and worked for the people who gave it to me. It "acts" like it's printing, that is, the paper goes through the printer, but there is...
    I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
    Please consider the following:
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
    Don
    Feb 05, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    Problem with ink refills
    Yes these two should work with your model. Here's also a link to the cartridges for this model for your reference.
    http://www.lexmark.com/lexmark/product/home/999/0,6970,204816596_653293766_1113019367_en,00.html?tabId=7'
    "Lexmark does NOT support the refilling of its ink cartridges.
    Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the printhead.
    Any damage to your printer caused by refilled ink cartridges may not be covered under your warranty."
    Jun 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Cannot install ink cartridges
    The manual may talk about a button (or combination) to press to get the cartridge to the centre. Some CANON printers do this.
    Mar 04, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    Refilling lexmark x5070 ink
    I have this same printer. The print cartridges have chips in them that disable them after a certain amount of print jobs, even if there's still ink inside. You can not refill them. I will never buy another Lexmark, they are obviously a greedy company that cares little about their customers.
    Feb 25, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    312 people viewed this question
    k24674
    jasbo
    jasbo
