Question about HP Officejet 4110 All-In-One InkJet Printer
Cartridge problem "Remove and check cartridge" or error with black cartridge
  • greg477 Apr 13, 2009
    Black cartridge was working fine then i got an error to remove and check the black ink cartridge. There is ink in it. It allows me to print the alignment page.
  • susiegandy May 01, 2009
    I had the same problem.. Did this cleaning procedure and it took off. Thanks.
1. remove the cartridge and check the cartridge no. is it supported or not
2. if its supported then clean the cartridge contact and carriage cartridge contact with clean cloth and then check
3 some time what happen if color carteidge sircuit is gone bad then also this issue is comming so please check with new pair of cartridge
if issue same after done these steps then go to the neareast service center might be carriage pcb or flux cable or logic pca one of these part might be goes faulty
Posted on Nov 20, 2008
SOURCE: hp7310 printer remove and check cartridge on right error
pull out the cartridge and shine a flashlight in and look at the flex circuit. Mine got damaged by the cartridge spring which gets loose. I think this is a common problem caused by a design defect. I am trying to talk to HP about it now.
Posted on Dec 31, 2007
Sandy4u
  • 107 Answers
SOURCE: cartridge error
Hi ,
hp is not recomanded the rifilled cartridges with printer .
& also printer is not detected refield cratridge as a full or new cartridge please check with new Hp orignal cartridge
it should be working ..................
if this information is useful for u please Rate me.......
Posted on Jun 15, 2008
SOURCE: wrong cartridge in hp5610; can't remove it
this happened to me and this is how i solved it. take a pair of plyers and grab the cartridge from the sides and pull. it took a couple of tries and it came right out, intact and the printer resumed working properly.
Posted on Aug 04, 2009
radar001
  • 1051 Answers
SOURCE: error message: remove and check cartridge on
If it's a new cartridge one of two possible problems has occured. 1.) The cartidge is not seated fully in the cartridge tray, or 2. when you removed the protective strip from the cartridge a small piece tore off and is stuck to the cartridge. This is a frequent problem. Uder good lighting check for any small stips of clear tape arounf the cartidge nozzels.
In addition, make certain cartifge is fully inserted in tray and locking mechanism is secure.
It sounds surpisingly simple, but I doubt anyone can say it hasn't happened to them at least once.
If it's an old carteidge the nozzel may be clogged. Remove the cartridge an either clean the nozzells with a moist Q-TIP, or dip the entire nozzel section in warm water for a few seconds. Put cartridge back in printer and print a test page. If you cleaned the nozzel with water you may finf you test page smeared with some water, but this will clear up.
Posted on Mar 31, 2010
Testimonial: "Great idea I will try it."
nirikip
  • 56 Answers
SOURCE: error remove and check cartridge on right I
May be you can try to perform partial reset by :
  1. Disconnect the power cord from the back of the product, and then wait for 20 seconds.
  2. Press and hold # and 3 on the product control panel while connecting the power cord to the back of the product.
  3. Release the buttons when the product turns on. The reset is complete.
Posted on May 13, 2010
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
10.92 errror message. I have install a new black cartridge but the message keep telling me to close the door. HELP PLEASE. THAQNKSw
10.92.XX says that the print cartridge XX(00=black, 01=cyan, 02=magenta, 03=yellow) is not engaged correctly.
Since the error occurred after replacing the black cartridge, it's a good bet that the black is bad.
Put the old black in the printer and see if the error goes away.
Open and close the front door slowly and look at the cartridges. You should see the cartridge flaps all open and close as you open and close the front door.
If the flaps don't all open and close, the cartridge lock mechanism could be broken.
You can run the DISABLE CARTRIDGE CHECK diagnostic. This will allow you to remove all the cartridges and install all or one in any slot you want. In your case remove them all and put the cyan in the black slot and see if the error goes away. If yes, put the black in any empty slot. If the error returns, the black is definitely bad.
Apr 18, 2011 | HP LaserJet 3600n Printer
Cartridge error refer device documentation troubleshoot
Remove the black cartridge and keep only the color cartridge in, and check the message. Now remove teh color cartridge and insert only the black cartridge in, and check the message. This should give an idea about which cartridge has a problem.
Feb 17, 2011 | HP Officejet 5610 All-In-One InkJet...
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
New black ink cartridge wont print black
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 10, 2010 | Brother Multi-Function Center MFC-3360c...
Printer does not recognize ink cartridge.
Remove the black cartridge and gently wipe the contacts on it with a dry cloth. Put the cartridge back in. If the error message is still there, I think you should buy a new black cartridge.
Apr 01, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Dell 944 error message 1102 after fitting new DellBlack Cartridge
hi there,
you can try these steps:
try to remove the new black cartridge. get a clean cloth. gently wipe the copper strip of the cartridge. unplug the power cable of the printer. gently wipe the contacts of the black cartridge carrier (where you put the black cartridge in). close the carrier, plug the power cable back in. install the black cartridge. then check for the error code.
if you still have same error code, try the old cartridge.
if the old cartridge still works, you need to contact dell for the replacement of the black cartridge (if you purchase the black cartridge from dell)
if the old cartridge is also giving same error. try the steps on the color cartridge as well, it might be with the color cartridge error.
or both.
worst case scenario the contacts on the printer carrier might be broken already.
but in this kind of situation. 98% it's the cartridge that's causing the issue.
have a great day :)
Oct 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP Officejet 4110 All-In-One InkJet Printer Logo
    316 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
