Question about Maytag Washing Machines
I have a stackable maytag full size washer dryer with digital controls. The washer is not responding. It worked after turning it on and off and changing the settings, but after it started washing, when the tank was full of water it stopped and would not start again. is there anything that I can do from here?
  • Maytag Master
  • 19,396 Answers
Try first unpluggiing the appliance for ten minutes or so.
If you still have the problem, then it can be a faulty control panel, a faulty pump, inlet valve or a different part, depending on what part of the cycle it gets stuck.
Posted on Nov 03, 2008
  • Ginko
    Ginko Nov 03, 2008
    If the cycle stops when the tub is full of water, that means that the problem is either with the timer control, with water heating, or with drain system.
    Check if the water is being heated regularly, if not check the hot water power supply, or in this case, as this is a washer with dyer/water heating system, have the heating element tested and eventually replaced by a technician.
    If the water is heating, but the washing machine is getting stuck with the tub full of water, and does not drain, then check the drain sysltem. Ispect and eventually unlock the drain hose. If the drain hose is fine, check the drain pump.
    If the machine fills the tank abnormally, with water getting up to the top, and eventually leaking out, then what is faulty or stuck is the floating sensor called water level switch, or a defective inlet valve.
    If you do not find any of the faults listed above, then the it is probably the control panel to be replaced.
    Here you find a generic diagram for washing machines, browse the mouse on top of the pictures to identify the parts descripted here in my comment:
    Top Load Maytag Style
    or
    Front Load Maytag Style
    If you want detailed schematics for your model, or you want to buy parts, insert the model number here.
    Or here.
    inIf this model has a built i
I have a maytag neptune washer/dryer stackable. Moved hooked it up dryer works great but washer wont turn on???
Make sure you have power to the outlet, I have seen where a 110 outlet was working on either the top half and not the bottom
Jan 30, 2015 | Maytag Washing Machines
MAYTAG STACKABLE WASHER FILLS BUT NOTHING ELSE
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Nov 05, 2013 | Maytag Stackable Washer Dryer
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Model SE9900 Maytag Stackable Washer/Dryer - 9E Error
According to my data, a 9E error indicates door latch malfunction.
Apr 21, 2017 | Maytag Washing Machines
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stackable w/d
Yes, it is inside the front washer lower front panel. Turn off poawer to unit and change w/ 1Amp 250V (regular of slow-blow). Then try only opening washer lid door with full dial pushed in (that would be the 'off' position. Only open/close lid w/ dial in off position. If washer works normally, may have a temp solution. Mine started this way, but ultimately the double relayed door lid switch was going bad and I had to replace it. Instructions/pictures below. Good Luck
AT702
Jan 27, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
