Question about HP P5302M Computer Speakers
Speaker doesnt give sound
I have a HP personal computer and currently my speaker system doesnt give out any sound. However, when i plugged in my headphone i could hear the sound properly. I also tried to use another speaker system and its working properly. In order to fix this problem i have tried the following ways from Microsoft troubleshooter but it still doesnt work: 1. plugged out my power supply for the speaker and keep it out for 30 seconds 2. made sure if all the cables plugged in properly 3. checked if all my sound systems are enabled 4. have the mute volume unchecked Please help me to solve this matter.. thx alot, i really appreciate it
  • Anonymous Apr 07, 2009
    no sound at all Companion 3
  • Anonymous Mar 17, 2014
    plugged in but no sounds, had sound then when I tried to do Skype the sound stopped working
    Scholar:
  • 85 Answers
Sounds like faulty speakers to me, have them replaced.
Posted on Jun 18, 2007
Im having a similar problem, try updating drivers and making sure everything's working. Mine is no use, im getting a computer guy to fix mine.
Posted on Apr 02, 2007
I ahd the smae problem, try cleaning the terminals where u plug the speaker. Also check to see if the power supply is not damaged! Also try pluging them into another power outlet
Posted on Mar 08, 2007
    Problem Solver:
  • 11 Answers
Based on the fact that you have put a headset in and another speaker system and it is working properly there is nothing wrong with your windows settings. I would leave them alone. The issue appears to be with the hardware. Have you attempted to plug the speakers into another source (ie. cd player, ipod, etc)? If you plug them in there and they don't work, take the speakers back and have them exchanged. If they're not under warranty you're going to have to either get them fixed or replace them. Good luck on this one! JC
Posted on Sep 30, 2006
4 Suggested Answers
SOURCE:
pagebor
  • 2785 Answers
SOURCE: my hp speakers dont work
dear sushiudon
plz check your speakers with another pc is it working there.plz post your findings
Posted on Apr 02, 2008
sodeep
  • 3267 Answers
SOURCE: standard speakers to the computer , low volume
Connections without soldering it does not give proper conductance to the speakers and the integrated audio is good enough for headphones but to get good sound you need an amplifier to increase the output. Alternative is to add a good sound card like 'Aureal' or Yamaha or Creative plus so many available mow in the market and neither are they expensive...........sodeep
Posted on May 11, 2009
coolhandan
  • 102 Answers
SOURCE: Can hear sound from only one speaker.
try to download vista drivers for this or go to compatbility to see if that works
Posted on Sep 21, 2009
I have compaq FLC presario speaker system and it doesnt work...want to get the correct software for it.....
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Mar 04, 2011 | HP Compaq Computer Speakers
There is no sound. I have connected it to my new Toshiba laptop
Hello there,
When you plugged it into your laptop, turned it on and increase the volume, do you hear only a humming sound from the speakers? Try to plug the speaker to an mp3 player as well to test if it still doesnt give out any sound. If it still doesnt, then your speaker must have a wiring connection problem inside that needs resoldering. Here I supposed that your laptop's internal speakers is working and is able to work with other audio devices like a headset or an earphone.
Dec 20, 2010 | Insignia 2.0 Speaker System (2-Piece)
Connected this dual speaker to my cmpact desktop comp and it does not want to work
First step is to assure that the speakers are working. If you have no other computer or sound system to test the speakers, then attach a AA, AAA or C battery to the speakers plug. It makes no difference in the polarity. If it makes a horrible white noise, the speakers are in good working order, if it makes no noise, the speakers are at fault. Should the speakers be ok, then in all probability you have a configuration problem. Go to control panel, select Sound and Audio devices, and check that the proper configuration options have been selected, and that the speaker volume sliders are at least at the 50% mark. If this doesnt solve your problem, then a computer motherboard component might have failed. Keep me posted
Mar 12, 2010 | HP JBL Platinum Computer Speakers
Speaker doesnt work after plugging into wall
ur speaker contains a small transformer in it. i think that transformer should be damaged. changing that will bring ur speaker to working conditions. you are kinda adventurous
Feb 12, 2010 | Audio Players & Recorders
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
No sound on my hp desktop
First and make sure you plugged the speakers into the correct port in the back of the computer. Green port is normally the port you want to plug into. 9 times out of 10 this is the issue. Next, try reinstalling the driver, by going to HP web site and downloading the most current driver. If you don't feel comfortable doing so, I am sure they have a return policy for repairs done incorrectly.
ArmyMason
Apr 01, 2009 | HP Pavilion XT936 power supply ** FREE **...
Dell speakers making a poping noise
may be problem with correct socket
Mar 14, 2009 | Audio Players & Recorders
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Mar 09, 2008 | Audio Players & Recorders
Hp speaker problem. Please help
Check the jack at the back of the computer see if it is inserted fully. if it is give it a spin between your fingers and wiggle a little to see if sound balances out. But don't forget there are several places to balance your speakers in your operating system on your computer. And what program you are using for playback. if the are self amplifing speakers unplug the jack completely out of the back of the computer. and plug in a pair of headphones and listen. If it is balanced there it is from the cable to the speakers. If it is not balanced it is the soundcard or the software. at least this will give you a place to start.
Aug 04, 2006 | HP (ZD929AA) Computer Speakers
HP P5302M Computer Speakers Logo
300 people viewed this question
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
