Question about Zenith Televison & Video
Projection bulb replacement
I have a Zenith rearscreen projection tv and the red projection bulb burned out. The model # of the TV is A50M91W.
Is it difficult to replace the bulb? How much is the bulb? Is there a part number on the bulb? How long do these bulbs generally last? I bought the unit used.
    Genius:
  • 2,920 Answers
The bulb is usually between 4 to 600 and they are not hard to replace if you take your time with it
Posted on Nov 03, 2008
I have Zenith rear projection TV Model IQC60H95W.The blue tube does not work. The red and green project. Is this a bulb or tube and are they available to purchase? The TV was made in 2001
This is a CRT(cathode ray tube) not a bulb. A Bulb is totally different. If you replace one Tube, you need to replace all 3 or the colors will never match properly. However, This model no longer has parts available. Even if they were, the cost would be close to $1000 in parts. I would not recommend repairing this TV.
Sep 14, 2014 | Zenith Televison & Video
Red and green doubled words on tv is this a bulb problem
No, it is convergence problem due to convergence output chips failure in rear projection tv.
Local tv repairman will fix it because it requires soldering work to replace bad chips in circuit board.
Thanks.
Mar 27, 2011 | Zenith R57W46 57" Rear Projection...
The bulb on my Hitachi Projection TV went out a second time. We just recieved the replacement. We still see a red hue (big circle) in the middle of the screen when the tv picture fades during a commercial....
hey I have a zenith projection tv that is only 3 years old and i have already replaced the stupid bulb 3 times at 450.00 a pop. No one told me at the time that i bought this tv at best buy that this bulb would have to be replaced this often. and the bad thing is i never watch this damn thing anymore but i paid 2200.00 for a tv that i cannot afford to watch and zenith will not help me at all with this problem
Feb 19, 2010 | Hitachi Televison & Video
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Sep 22, 2009 | Zenith R57W46 57" Rear Projection...
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
I have what I believe is a convergence problem. The red line curves down at the sides on the adjustment screen and when I am viewing TV the picture has a red ghost curving up at the sides of the picture....
Hi, this is a convergence chip failure and it can only be corrected by replacing the entire convergence board in this unit. This Board regulates and collaborates the RGB streams. if there is an apparent malfunction, it will become impossible to correct the issues you are experiencing at this time.
Simply replacing the convergence board or chip set will fix this issue.
May 16, 2009 | Zenith A50M91W 50" Rear Projection...
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Green spot on the middle of screen.
If the spot is perfectly round then most likely you have phosphur burn on 2 of the CRT's. If it uneven then maybe it is a spider who has made his home in there (not uncommon as it is warm and dry which is what they like).As far as cleaning goes, don't use standard glass cleaner as it will damage the screen. Use warm water and a soft towel, or purchase glass and plastic cleaner which is ususally a foam type spray.
Jan 25, 2007 | Zenith A50M91W 50" Rear Projection...
A50M91W Service Manual
Sorry man. I looked and looked and dont see a model such as the A50M91W or the IQC50H50H95W? Are you sure of the models?? Cause my connection for Zenith even has inported set manuels available, But im told NO such model Found. So they told me to advise you to look in your owners manual for a contact # for service and call them and see if they can get it for you. Or call here 1-877-993-6484. OH BTW what is the problem your having??? Good Luck
Jun 28, 2006 | Zenith IQC50H95W 50" Rear Projection...
Televison & Video Logo
450 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
