Question about Archos AV 500 400-Hours Video Recorder
Av 500 froze while updating firmware, power light on with adapter but doesnt not work.
This is a new unit with less than 6 hours of use. I was trying to copy my tv show from unit to my computer (i assume that i should have been able to do this, but i kept getting an error message on PC that i didnt have enough storage. I went to to find suggestions or a fix to my problem. I saw there was an update for the firmware to .12 version, and since i was running .11 i figured i may as well update. I downloaded update to my pc, directions said to copy it to the data folder on the av500. Download went fine. I was in windows devise mode so i unplugged the usb, i restarted the av500, found update in the menue and then clicked on it. A blue bar appeared at the bottom of the screen, it appeared to have updated, but the screen froze at the blue bar. I let it sit for a few minutes while i tried to find the directions page again to see if i did something wrong, but i believe i followed the directions exactly. The screen did not change after at least 5+ minutes, i tried to power off the unit but it would not turn off. I unplugged the charger, tried again to turn it off, but still wouldnt turn off, the only other thing i figured i could do is take the battery off. (expecially since i keep hearing about defective batteries in several computers and the fire hazard they are) The unit doesnt power up or boot up (not sure of terms to use) If i plug in the adapter/charger, the green light comes on but it doesnt function, only a black screen. I have no clue of what i could have done wrong......... its new, only had it for 2 weeks, i didnt even get a chance to put music on it.. My feelings are hurt.. My husbands work bought this for him to use........ There is no reciept to return it/exchange it. and it was purchased with many others......... To much red tape to track down purchase order ect.......... I just want this thing to work...... Please help...........
Re: av 500 froze while updating firmware, power light on...
Press the power off button and volume up button simultaneously for a couple of seconds. Rick
Posted on Jan 28, 2007
0 characters
3 Points
I own 3 of these. Two of them have been hooked up for over 3 years and worked perfectly until yesterday. All of a sudden, the remote wouldn't work and I couldn't turn the unit off with the power button. ...
If you are using these DVRs over the air only, with 1.2.06 installed you have to run the G* Test in the 9012 menu, to get the digital data going, after removing power. That is why your clocks are --:--. I highly recommend that you update the firmware in both of these units to 1.2.21, to avoid having to mess with the G* Test.
Aug 17, 2010 | Sony DHG-HDD500 400-Hours Video Recorder
R15 DVR locked in record
2 months ago my R15-500 stopped working. The "Record"(yellow) light was dim on the front of the DVR and a lightly audible clicking noise could be heard from inside the DVR. So I searched the internet and found this FIXYA site. I disassembled the DVR as instructed and removed the power board. Sure enough the Capacitors were bulging on top. I replaced all of the capacitors on the power supply output, I think 6 altogether. I reassembled the unit and it worked great.
Jul 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
Archos AV560 - Not charging
charger was failing - tried new charger & it worked
Jul 13, 2008 | Archos AV 500 400-Hours Video Recorder
AV 500 "No input signal" on multiple attempts
Check to make sure all of the configuration on the AV 500 are as they should be. If they are you are looking at a defective unit (might be hardware based) if it is I would suggest that is you do not have a background in electronics to take the unit to a repair shop. If you do have experience you will need the following items: A schematic diagram of the AV 500 A Multimeter to measure the voltages at test points of the AV 500 An Oscilloscope to measure the signals and levels at test points of the AV 500 if you have these pieces of equipment then you will want to start your test at the dectector stage (this is where video and audio are separated from the IF which is derivied from the RF so if you have video and audio at this point you know the input RF-IF-detector stages are working. Now based on your troubleshooting you inputted signal at the video processor by using the the video inputs, so from this I am going to take a stab at saying the problem more then likely would be located in the stages at and after the video processor stage (since in this case no signal may mean no video signal as opposed to no RF signal).
Sep 06, 2007 | Archos AV 500 400-Hours Video Recorder
Archos gemini av 500
Is the drive recognised by your PC when you plug the Archos into the computer?
Mar 02, 2007 | Archos AV 500 400-Hours Video Recorder
My Unit Will Not Power Up
Not sure if this is a solution for you. I had a problem with the DC power input jack on the player going bad. The batteries would no longer charge. I bought an extra battery and a USB charger from ebay. Now I'm good for two battery cycles and it works again. Although it will never charge it's own batteries or work off of AC power it does still work.
Dec 21, 2006 | Archos AV 700 160-Hours Video Recorder
Av 400 - will not turn on
Hi, my archos does the exact same thing, however, when I press on, it turns on, then I hear a "click" and it turns itself off. Only when I have the charger plug in does the archos logo continue to remain on the screen. Did you find out what our problem is?
Dec 22, 2006 | Archos AV 500 400-Hours Video Recorder
Won't turn on
I had this problem. I was mad. What I do now is not a "fix", it is a workaround. I hold the machine facing me, like I am watching it. I then twist it torsionally, top left corner away, bottom right corner toward me. It's like there is a crack in the circuit board or something. That works.
Aug 30, 2006 | Archos AV 500 400-Hours Video Recorder
Archos AV 500 400-Hours Video Recorder Logo
308 people viewed this question
Top Archos TV Receivers & DVRs Experts
Jaime Hernandez
Are you an Archos TV Receiver and DVR Expert? Answer questions, earn points and help others
