Question about HP Office Equipment & Supplies
The fax machine jam when i try to send a fax - HP Office Equipment & Supplies
  • 24 Answers
What type of machine?
Posted on Nov 03, 2008
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
HP 1050 Fax Machine will not send out faxes. It sends the first page then prints out paper saying paper jam, but we have not paper jammed in the machine.
Sorry but still do not have it fixed...i printed off the manual for this fax but our problem is not on the trouble shooting list. But i'd think you would be able to tell how to fix it without charging for the sollution.
Oct 20, 2009 | HP 1050 Plain Paper Inkjet Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
Paper jam, error message, fax send comes out not ledgable.
Code 43 is a line error according to Panasonic.
I had this issue trying to send to a client yet I could send faxes to other #'s. So in my case it was a dead fax on the other end of the line.
Jun 13, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
20 people viewed this question
Ben Johnson
