Question about Casio Exilim EX-Z750 Digital Camera
Lens will not open
The lens will not extend or open, nor will it close completely. I can view pictures, but get a lens error message in the "take pictures" mode.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Posted on Jan 15, 2013
  • 3 Answers
SOURCE: Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Posted on Jun 28, 2007
SOURCE: lens open/close problem
I have two of these cameras for at work. Both have this problem. If you hold the power key and repeatedly press the top key (one that shoots the picture) or hold the power key and then press and hold the shot key the camera is forced to take a picture. The camera seems to be ok then. There is no damage to the lens, as the pictures and quality are the same. It is definitly a design flaw, and/or software issue. Good Luck, and keep trying untill it fixes itself.
Posted on Sep 16, 2007
  • 34 Answers
SOURCE: Casio EXILIM camera lens will not extend fully!!!
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. my username. ;)
Posted on Jan 25, 2008
  • 34 Answers
SOURCE: lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. my user name.
  • 4 Answers
SOURCE: When I turn on the camera the lens comes out then
Possible broken spring mount in lens. This spring holds the focus lens. I had the same problem on an EX S600 and was able to fix it by taking the lens assembly out and taking it apart and making a spring mount out of a small piece of wire and glueing it in. This is not an easy job as everything is very tiny. It takes time and patience. Seems the camera tries to autofocus but can't because the spring is not connected. It then just shuts off.
Posted on Aug 27, 2009
Lens error
I've got the answers...
Problem: Lens error.
Symptom: Lens will not extend upon power up.
Cause: Lens is impeded while trying to extend.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the main drive gears to be damaged.
Solution: Replace the main drive gear assembly. This should only be done by a qualified tech.
If you've experienced this you know exactly what I mean. This should clear up any notion that the "Lens Gods" have cursed you. Although this may have appeared to be a mystery, it's always caused by something!
Symptom: Lens extends, makes a few buzzing noises and retracts, resulting in "lens error" message.
Cause: This is caused by damage to the focus lens often by impact, or sand in the mechanism.
Solution:The focus lens gears either need to be replaced or the assembly completely rebuilt. Again, this should be done by a qualified tech. It's a very delicate process.
Problem: Aperture unit failure
Symptom: images appear to be washed out, over exposed and often have horizontal lines through them.
Cause:The aperture unit is either stuck, damaged or not receiving the proper electrical signal to activate. The result is that the aperture remains open after the picture is taken and CCD is over exposed.
Solution:Completely rebuild the aperture unit, which requires complete lens dis-assembly and rebuild. Again, this should be done by a qualified tech. It's a VERY delicate process.
Additional details in THIS LINK.
Hope this helps.
Apr 27, 2011 | Casio Exilim EXZ75 Digital Camera
I bought my camera 6-7 months ago. Now when I try to take pictures the lens comes out but I can't take a picture. and then a Lens Error message shows up on my screen and the lens closes. I can view...
Leaving the camera on and putting it where pressure is applied on the extended lens will damage the gears driving the lens mechanism in and out.There fore the problem was due to a broken gear mechanism.You need to bring it to a service/repair shop, because there are no owner serviceable parts inside and which the service guy has.If you camera is under warranty(usually 1 year) return it under the warranty and get a replacement.
Feb 02, 2011 | Casio Exilim EX-Z750 Digital Camera
Lens error, restart camera message
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Nov 15, 2008 | Canon PowerShot S3 IS Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints. reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lens error
Dec 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Casio Exilim EX-Z750 Digital Camera Logo
26 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
