Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Icemaker makes ice, but doesn't dump it.
My icemaker has frozen ice in the icemaker but won't dump it into the dispenser. There is an infared sensor, which seems to be working. The dispenser is empty. What could cause this problem?
  • 59 Answers
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
Posted on Nov 03, 2008
The icemaker gear is plastic and breaks very easily. I have had to replace mine twice. The tech comments were: "found icemaker gear broken, installed module kit and tested OK" The part number is :MOTOR-MODL 46 106 8201515 1.
Posted on Nov 08, 2008
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser on the door works, but the ice maker won't make ice
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Kenmore Refrigerators
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Ask maker is not working - water is getting to water dispenser but not to ice maker. i am not sure what the infared does in the freezer
Pour about 1/2 cup of water into the icemaker and so if it dumps after freezing . If so , then watervalve or frozen water line in top of freezer is the problem .Squeeze the black fill tube to see if frozen . If ice stays in the ice maker , then the icemaker is the problem . The infra red is an electric eye which cuts the icemaker off when the bin is full .
Jul 12, 2009 | Refrigerators
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
350 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
